Burned dvd off of my computer it willl play on computer but no on regular dvd player
  • 13,433 Answers
Your dvd player probably doesnt support the disk you burned the movie on. or then you did it wrong, the movies need to be converted into dvd movies first.
http://www.microsoft.com/windowsxp/using/moviemaker/expert/bridgman_burndvd.mspx
Posted on May 01, 2008
I have never been able to play a slideshow 0n my dv454 no matter where i had the discs burned what am i doing wrong? ps the discs play in other dvd players
Check to make sure that the format of the discs burned are acceptable by the dvd player, some companies do not support certain formats. refer to owner manual as to which ones are readable on your particular dvd player. if the dvd player plays other regular/non-burned discs, this is the probable issue,...more info is needed if this is not solution.
best of luck
Oct 17, 2010 | Pioneer DV-454 DVD Player
Does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
Jun 18, 2010 | Cyberhome CH-DVD 300 DVD Player
My computer doesn't play movies taken with my ls80
This camera uses quicktime. Windows Media Player should play your molvies. If not, try VLC media player. You can burn a dvd that will play on a regular dvd player. Download DVD FLICK which will convert the files into MPEG which play on a dvd player.
Jun 12, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
I have tried burning 2 dvd's now one was a double layer and one regular, they play on the computer but not on the house dvd player, I haved tried two diffrent dvd players, any ideas?
It could be that the two home dvd players you tried would not play the format of your burned discs. Not all units will play both +R's and -R's. The other problem could be that your burner is out of alignment enough that only your burner will play the disc's you create on that unit. If you have a warranty on the burner it would be worth either getting it tested or exchanged.
Jul 25, 2009 | Mad Dog Multimedia DVD±RW Dual Layer...
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
The durabrand 1700
It could be the codec u use to encode the movie,
secondly could be a firm ware problem of your dvd player.
Other than this I can't think of any other reason. or just may be the type of recoreder u use or the recoding programe. If u had check these, then get another player
Sorry, this is all I can think of.
PS. the player firmware is the main reason to me.
Cheers
Rifaa
Nov 18, 2008 | Durabrand PDV-705 Portable DVD Player
I WANT TO BURN MY DOWNLOADED MOVIES ON DVD-R &PLAY THEM ON A DVD PLAYER
I always use Aimersoft DVD Creator, it can easily convert all popular video formats (AVI, MP4, MPG, MPEG, 3GP, WMV, ASF, RM, RMVB, DAT, MOV, FLV, etc) to DVD and burn DVD movie played on portable and home DVD players, that's very good, you can check it out here for free:
http://www.aimersoft.com/dvd-creator.html
Apr 14, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Acer dvd problem
When you burn dvd's to play on DVD players dont burn them as Data dvd they will not play. When you burn the DVD movie try to burn it using a DVD player compatible profile and this depends on the application software you are using to burn the DVD.
Do the DVD play on your computer from DVD or even from the file on hard drive.
If it does not play from the file on hard drive then the file is corrupted on downloading or you dont have a proper dvd palying software like PowerDVD
If it plays from the software but does not play from the DVD on your computer, then it means your DVD burner softaware corrupts file information on burning. Try using a different burning software.
If it plays DVD on your computer but not on the DVD player then your DVD burning profile you selecting is not compatible with your player its possibly burning Data DVD.
Mar 22, 2008 | Computers & Internet
DVD disk
check to see what format your computer burns on.[ex:dvd-r, dvd-rw,dvd-+r,dvd-+rw]different dvd players play certain dvd formats.the format for burning on your computer is probably different from the dvd players that aren't playing the disc.you also must finalize the burned disc.
good luck
wg
Feb 01, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
Mini dvd can be burned on a regular dvd, but cannot be played
convert them to normal format using file convertor or record in VR format instead of Video format
Oct 24, 2007 | Canon DC210 DVD Camcorder
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
