Question about Kenmore 15212 Mechanical Sewing Machine
Button holer It is the first time I've used it. The attachment sews the tack bar and goes back the first side. It then does a little tack bar (half the size of the first) and stays there. It doesn't do the other side. Why?
  • Anonymous Jun 18, 2008
    buttonholder will not feed. it stays in one spot
Refer to step 5 in the instruction book. Turn the stich selector to the reverse arrow and back to the buttonhole symbol. This re-sets the machine.
Posted on Jul 13, 2008
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Mar 12, 2015 | Sewing Machines
Auto button holer only sews half will not go back
rotate fabric under presser foot and continue .should sew the other half .
Feb 09, 2015 | Singer Sewing Machines
Auto buttonhole not working on manual setting
Could be a worn cam, but more likely a dirty or dry machine.
Jan 04, 2014 | Kenmore Sewing Machines
How to make a butten hol
This is a 4 step process. You start at the first step and it sews backwards first, Next you perform step 2 to sew the bar tack. Third you sew the right side of the button hole as it comes towards you. The final step is another bar tack which is the same as the second step.
Dec 26, 2013 | Husqvarna Huskystar 215 Sewing Machine
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
I can''t remember the steps to make a button hole using my Bernina patchwork 140. I have the # 3 foot. What button do I push to turn the corner manually?
you can download a manual for the Activa 145 here, buttonholing steps would probably be very similar for your model
http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf
It says you sew one bar, then press the reverse button and the automatic function then sews the bar tacs, other side, bar tack and finishes.
Jan 29, 2011 | Bernina Activa 140
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
Apr 07, 2009 | New Home MX-3123 Computerized Sewing...
Kenmore 15212 Mechanical Sewing Machine Logo
102 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
