Question about Dryers
Heater element will not heat drum. - Dryers
  • 78 Answers
If it's turning and not heating, chances are that it could be a broken heating element or it's not getting the full power. before taking the dryer apart, go to the breaker box that supplies power to it and pull the breakers completely off and then on. if that doesn't work, you could have a bad breaker or a bad heating element. if one of the breakers seems kind of loose or wiggles easily it needs changing anyway.
Posted on May 02, 2008
I have bought a new drum for a hotpoint aqxxd169pm. But it has come without the heating element integral with the drum. I do not know how to get the heater element out of the old drum and the refit it into...
heater element should only be held in by 1 bolt which runs from inside to outside element faxe......remove the nut..........carfully prise the element out...its only kept in place by rubber ..washing up liquid may help.......
Mar 09, 2015 | Hotpoint Washing Machines
No high heat in dryer
This type of dryer has 2 rows of elements. If one is out then you will not have high heat.
Basically to get into ge dryers your start by popping the top then removing the front. Then the drum comes out.
Dec 05, 2012 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
Aug 15, 2012 | GE Dryers
Where is the igniter located on dryer
An easy answer: gas (natural gas) dryers have igniters, but your electric dryer has no igniter,
instead it has a heating element (a zigzag arrangement of wires similar to that found in a space heater). Remove the back of the dryer - the heating element will be enclosed in an air duct that feeds heated air into the drum via a vent at the top back of the drum.
If you look into the drum, you can see the vent cover that covers the heated air inlet at the top back of the drum.
Sep 12, 2011 | Whirlpool LER4634J Electric Dryer
The dryer is not producing heat.
If the Drum is rotating and the Blower Motor is operating (meaning you can feel air moving in the Drum), then the likely culprit that is causing your lack of heat is the Heater Box. By box, that means a metal box that usually sits behind the drum containing a heating element that heats the air going into the drum. If this heating element is not working then, you heater box is at fault. Don't assume that the element is bad, more often than not is is a thermostat, switch, or perhaps a wire that is connected to the box. While the other electric components on your dryer operate at 125VAC, the heater box uses 220V AC. You will need to get a multitester to check continuity. On some models, you can access the box from the box, but on others you will have to remove the front door and take the drum and belt off (a pain in the neck to remove). Hope that helps.
Jan 12, 2011 | Dryers
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
Apr 20, 2010 | GE DVLR223 Dryers
Gibson electric dryer doesnt heat up
you may have shorted you thermal fuse. or the overload that is attached to the element housing. Good luck.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Ge electric dryer dbsr453 heater element
hi thanks for the question if you have the drum out the heater should be at the back you should be able to see the element
Jul 17, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
