Everytime that I go to print something it comes up that the #5 black cartridge is empty even though It is filled. I do not have a orange light on my printer to hold in for the five seconds that it reccommends.
    President:
  • 2,712 Answers
Make sure that the cartridge is inserted properly and the plastic tab covering the contacts has been removed. Also try cleaning the contacts gently with some isopropyl alcohol and a q-tip.
Should that not work, unplug the printer from the mains and the PC for about 15 mins. Press the power button on the printer in this condition for a couple for minutes (2-3). I know this wont show or do anything, but it will help to disacharge any latent charges. After 15 mins, plug the printer back into the mains and then the PC.
Try it now and see if it works. If it still doesn't, then try replacing the cartridge. Its faulty.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
How can I over ride my ink level tracker on the Kodak ESP 7 printer? The printer must be using a counter because I never print in color but my color cartridge keeps showing that it is going down. ...
The Kodak printers are designed in such a way so as to work with combination of Both color and black ink..In other printers,the prints are not that sharp,but In kodak printers color are awesome because even if we print black and white,the color from the color ink is also taken to give you those lifetime prints.Unfortunately There is no way to overcome this ink indicator.You cans et the preferences in the printer settings to print in black and white in your computer .
Dec 30, 2009 | Kodak ESP 5 Printer
MP140 reset problem
this signal cartridge miss mach please reinstall your cartridge power of & power on again then 1 is active printer is ok or change your printer cartridge Black and color both
Sep 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to take empty cartridges out
1. Cover the outlet hole with the orange outlet seal that came with the cartridge (a rubber band will hold this in place) to prevent ink loss during refilling or with your finger over the outlet port while wearing latex gloves .
2. Use the "L tool" provided to push the Sealing Ball into the cartridge (tap on the 'L tool' if the ball is stuck). If you can't see the ball just above the "push" then peel back the top label on the reservoir side of the cartridge to expose the Sealing Ball. This is the ball Canon used to plug up the hole after they refilled the cartridge.
3. Attach the needle to the syringe and fill with the correct color ink.
4. Slowly inject approximately 13 ml. of Black Ink or 6 ml of Color Ink slowly into the filling hole until the chamber is almost full. Unused ink may be returned to the bottle.
5. Seal the hole using the Green Plug. Put your finger on the green plug and twist until it is seated well in the hole.
6. Remove the orange outlet seal (or your finger) from the outlet hole.
7. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
8. If you have trouble getting your cartridge to print and the sponge side of the cartridge looks dry then drill a hole (or burn a hole with a hot paper clip) into the top of the sponge side of the cartridge. Stick the syringe needle into the sponge and fill with ink. You do not need to seal this hole.
If you are filling cartridges to use later, leave the orange outlet seal rubber banded onto the cartridge. This will prevent your sponge from drying out.
Note: On the CLI-8 and PGI-5 series cartridges, there is an electronic counter embedded in a small computer chip/board. This counter starts at a high number and decreases for every character printed. Eventually, the counter reaches zero. At this point, an error message is generated by the printer. If you click "OK" to the error message, the printer will continue to print.
If you have trouble getting your printer to print because it thinks the cartridges are empty. Look on your printer for an orange blinking light. This is your reset button, usually the paper feed button also. Hold this button in for 5 seconds until the light goes out. Note: this will not reset the ink level back to full.
Dec 10, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Pixma MP610 - fab machine - only problem is that the large of the black cartridges empties - never uses the smaller one (No 5) why? It refuses to print if the No 8 is empty. What do I need to do please?
The large of the black cartridge (5) is for ordinary paper in printing menu of computer. Selecting photo paper uses only the small black cartridge (8) and the color cartridges are used to make black even for gray black printing. Choosing ordinary paper, you can print in black 10 even 20 times with the large black cartridge (5) (by refilling and quoted as empty) . You simply need to press a long time the hold button, as explained in the manual on the printer CD, to continue to print with an empty cartridge. (at least in Europe)
The color cartridges are slightly used even when printing only in black and become empty, even if you never use the colors!
Jul 28, 2008 | Office Equipment & Supplies
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
37 people viewed this question
k24674
jasbo
jasbo
