On my computor running vista i keep getting the following error microsoft volume shadow copy service has stopped working and was closed. any ideas how i can fix this regards mike
    President:
  • 1,257 Answers
Best Solutions :
Type "services.msc" in RUN dialog box and press <Enter>. Now in the right side left click on any of file and press "V" and it'll show you "Volume Shadow Copy" in list.Double click on it and make sure its set to "Automatic" and running. Otherwise change it to "Automatic".
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Posted on May 01, 2008
  • 13,433 Answers
Disable the service,
hold down windows key and press r
type in services.msc
then from the services list find Microsoft Software Shadow copy Provider - thats the one i beleave.
Right click, properties, startup type, disabled. then stop the service.
You shouldnt get any more errors and the service is not required so everything should work normally.
Sytem restore wont innitiate
Check whether Volume Shadow Copy Service, System Restore Service is started and Set to Automatic
1. Type Services.msc in Start Menu search box, hit Enter. 2. Make sure that the Volume Shadow Copy Service is Running and set on Automatic. 3. If the Status of System Restore Service is not Started, Start it. Also set it on Automatic if it is not.4. restart your computer.
Now try to do a system restore.
You may also download the Norton removal tool and completely remove all the components of Norton. Check if that helps.
Check how the computer works in safe mode.
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
If the computer works fine in safe mode, then do a clean boot.
Refer this KB article:http://support.microsoft.com/kb/929135
Also, run System File Checker tool (SFC.exe) to make sure system files are intact and to replace the file. Follow these steps:
1. Click Start, and then type cmd in the Start Search box.2. Right-click cmd in the Programs list, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue3. At the command prompt, the following line, and then press ENTER:sfc /scannow
http://support.microsoft.com/kb/929833
Nov 24, 2013 | Microsoft Windows 7 Home Premium 64BIT...
MY LAPTOP IS HP PAVILION dv6 I get the error message vssx80042317 or vss writer failed when I try to run a restore. Also in IE9 when I click on a link nothing happens.
1. Click Start, click Run, type Regedit, and then click OK.
2. Locate and then click the following registry subkey:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\EventSystem\{26c409cc-ae86-11d1-b616-00805fc79216}\Subscriptions
3. On the Edit menu, click Delete, and then click Yes to confirm that you want to delete the subkey.
4. Exit Registry Editor.
5. Click Start, click Run, type services.msc, and then click OK.
6. Right-click the following services one at a time. For each service, click Restart:
  • COM+ Event System
  • COM+ System Application
  • Microsoft Software Shadow Copy Provider
  • Volume Shadow Copy
7. Click Start, click Run, type cmd, and then click OK.
8. At the command prompt, type vssadmin list writers, and then press ENTER.
9. If the VSS writers are now listed, close the Command Prompt window. You do not have to complete the remaining steps. If the VSS writers are not listed, type the following commands at the command prompt. Press ENTER after each command.
  • cd /d %windir%\system32
  • net stop vss
  • net stop swprv
  • regsvr32 ole32.dll
  • regsvr32 oleaut32.dll
  • regsvr32 vss_ps.dll
  • vssvc /register
  • regsvr32 /i swprv.dll
  • regsvr32 /i eventcls.dll
  • regsvr32 es.dll
  • regsvr32 stdprov.dll
  • regsvr32 vssui.dll (does not work in Windows XP)
  • regsvr32 msxml.dll
  • regsvr32 msxml3.dll
  • regsvr32 msxml4.dll
Note The last command may not run successfully.
10. At the command prompt, type vssadmin list writers, and then press ENTER.
11. Confirm that the VSS writers are now listed.
12. At the command prompt, type vssadmin list shadows and then press ENTER.
13. Confirm that there are no errors listed. On Windows XP you should see: No shadow copies present in the system.
14. Congratulations your machine should work again with any VSS compatible programs.
Oct 27, 2011 | Computers & Internet
Ved opstart af window defender
From your description, I understand the issue to be: you received VSS error 0x8007042d.
I. First please re-registry the following DLLs to see if it helps:
1. Stop the Volume Shadow Copy service: Open a command prompt and change
directories to \WINDOWS\system32 (this is important when you begin
registering the DLLs):
net stop vss
2. Then register the following DLLs and services (be sure you're still in
the WINDOWS\system32 directory at your command prompt):
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 es.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Start the Volume Shadow Copy service by running "net start vss", do a test
backup and see how it goes.
II. If the issue persists, Let's perform these troubleshooting steps:
1. Make sure you can use OSQL to connect to every running instance of
SQL/MSDE on the box, if you can not disable all of the instances.
You can find all of the instances installed on your server, by looking at
this registry value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL
Server\InstalledInstances
The syntax would be "OSQL -E -S <servername>\<instancename>
For example OSQL -E -S server\SharePoint
If you can't connect to the database, then it will cause this type of
failure.
Also make sure that each of the SQL/MSDE instances is either running under
the Local System account or a Domain Admin account.
2. The issue may occur if there is corrupted data on the drive to be backed
up. Please run CHKDSK on each drive with the /f switch to fix the errors on
the disk (if there are any).
3. Per my experience, this issue can be due to VSS thinks the system is
still in setup process. Please perform the steps below to check the status.
WARNING: Using Registry Editor incorrectly can cause serious problems that
may require you to reinstall Windows. Microsoft cannot guarantee that
problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk.
Open the registry and locate the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\Setup
Ensure both registry values are set to 0:
- SystemSetupInProgress
- UpgradeInProgress
4. If the issue still happens, reinstall COM+ by following these steps:
A. Backup and then delete HKLM\Software\Microsoft\COM3
B. Boot to Recovery console and rename clbcatq.dll to ~clbcatq.dll. Be sure
to use the tilde.
C. Boot to normal mode and in Control Panel, open the Add or Remove
Programs tool, and then open the Add/Remove Windows Components tool. Do not
make any changes, just click "Next". This reinstalls COM+.
NOTE: You must have your Windows Server 2003 SP1 files available during
this step.
Hope above information helps! I am happy to be of assistance to you and
look forward to your reply!
May 31, 2010 | Microsoft Windows Vista Ultimate Edition
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
BCCCode 18 BCP2: fffffa80056befc0 Catastrophic Failure: 0x8000ffff
uninstall all SQL components from the list of Programs installed
______________________________________________________
Catastrophic failure (0x8000ffff)
Cause
Any of the following could contribute to this issue:
An application is interfering with System Restore.
One or more of the core System Restore files are missing and/or corrupted.
The Volume Shadow Copy Service (VSS) has been disabled. System Restore depends on VSS volume snapshots being created via Shared Protection Points (SPP). System Restore cannot function if snapshot creation via SPP breaks or is disabled or if VSS is disabled.
Resolution
To resolve such issues, use these steps:
Try to use System Restore from WinRE, Safe Mode, or Windows Vista in a clean boot state. If that fails, proceed with the next steps.
Check for the following files in the %windir%\system32 directory:
Srrstr.dll
Srclient.dll
Srcore.dll
Rstrui.exe
Follow the "Restoring Core Files" section later in this document. You might want to follow the instructions in that section to reregister Srcore.dll. Keep in mind that you are not able reregister Srrstr.dll, Srclient.dll, and Rstrui.exe as doing so produces an error message.
Check that Volume Shadow Copy Service (VSS) is not disabled.
Check for either of the following registry keys:
HKLM\Software\Policies\Microsoft\WindowsNT\CurrentVersion\SystemRestore
HKLM\Software\Microsoft\WindowsNT\CurrentVersion\SystemRestore
If you find a DisableConfig DWORD set to 1 in either of these keys, export the key and delete it.
Try System Restore again.
Oct 04, 2009 | Gateway Computers & Internet
Unable to create system restore point
GOOGLE found:
Run services.msc and make sure Volume Shadow Copy is stopped. Then locate and delete any System Volume Information folders on the root of any volume that was previously being monitored by System Restore. You may need to alter
Folder Options/View tab/Advanced in order to see these protected system folders. Reboot the system and retry turning it back on.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
May 30, 2009 | Microsoft Windows Vista Ultimate Edition
Documents in vista
Vista is a wonderful new OS that has volume shadow copying, what that does is it saves versioning information. IE: I create a new document and every day I go through and add to or edit the document, oh darn, on day 3 of that document I made a mistake and I need to go back to that version of the document. Thanks to volume shadow copying this is possible, unfortunately when the shadow is created is unknown so it is at this time that the documents would be made unavailable while they are being archived. It never happened in XP because XP didn't have this capability, but then again if you needed a version of a particular file, you were SOL weren't you?
Jan 01, 2009 | Microsoft Windows Vista Home Premium with...
Volume shadow copy backup error : 800423F1
http://support.microsoft.com/kb/833167
u may reffer this for sol.
Jun 13, 2008 | Microsoft Windows Server Standard 2003 for...
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
