Question about Microwave Ovens
My sharp carousel microwave is not heating anything up. Occasionally it will heat up a little but no where near what it should be. Last night the display showed "EE" Can you help me? -Ashley
    President:
  • 2,712 Answers
It looks like the magnetron or a component like a capacitor or a resistor on the control PCB may be failing or is kaput.
It is best you take this to a service center or the point of purchase and get a qualified technician to look at it. It can be hazardous to open the microwave yourself, if you have no prior experience.
If it is still under warranty, I recommend you get it replaced.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
I have a sharp carousel but the convection oven is not heating up. The microwave works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
I have a Sharp Carousel R-590 microwave that is about 10 years old. I fixed popcorn last night and after it stopped I added 30 seconds. It appeared to run but with a different and louder noise. However,...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps
Dec 31, 2010 | Microwave Ovens
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
