Question about Palm Treo 650 Handheld
TREO 650 I have 800+ contacts in my TREO and want to transfer them to my SIM card. How can I transfer all contacts at one time?
  • priya0331 Aug 28, 2008
    I have 600 + contacts in my TREO and want to transfer them to my SIM card. How can I transfer all contacts at one time?
  • Palm Master
  • 13,433 Answers
Im not sure about your model but, select them all first and then add to sim?
You might need a program todo it for you thought.
Posted on May 02, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Tip
Poor Palm Treo Battery
If you encounter a poor battery life on your Treo 680 and you have to recharge very often even if not using the phone function, the issue might have been caused by an incorrect first charging of the device. Please follow the steps below to solve the issue:
1. Connect your Treo to the charger.
2. Remove the battery from the Treo and wait for at least one minute.
3. Remove the SIM card from the device and wait for another minute.
4. Put the SIM card AND battery back into the device and charge the Treo for at least 4 - 6 hours. Do NOT press any key after reinserting the battery. Do NOT switch your TREO On or Off either, it will do so automatically after a short time. Do NOT enter the SIM card PIN if prompted to do so, just wait!
After this procedure, that can be performed and repeated any time, you will now dispose of the full charging capacity and the display of the remaining battery power works correctly.
on Mar 15, 2008 | T-Mobile Dash Smartphone
How do I transfer all contacts to my sim card
You will have to transfer your contacts one at a time. To export a contact's phone number to a Subscriber Identity Module (SIM) card in a BlackBerry smartphone, complete the following steps:
  1. Open the Address Book application from the BlackBerry smartphone Home screen.
  2. Click the contact that you want to transfer to your SIM card.
  3. Highlight the phone number you would like to transfer.
  4. Display the menu on the BlackBerry smartphone.
  5. Click Copy to SIM Phone Book.
  6. Make sure that you are attempting to transfer the correct informaton to your SIM card.
  7. Display the menu on the BlackBerry smartphone, and click Save.
Feb 16, 2010 | RIM BlackBerry Pearl 8100
My voice cannot be heard by other person for brief periods
If the problem repeated when you swapped your SIM card to another phone, it rules out it being a hardware issue. You can take your SIM card to a cellular store and have them replace it. That should fix the issue. I doubt it is the card itself since the card simply holds your account info for accessing the network. It sounds more like an issue within the network where the internal settings associated with your SIM # weren't properly set. Getting a new SIM card will force the system to fully set and associate your account with the SIM and should (fingers crossed) help fix the issue. Good luck!
Aug 31, 2009 | Palm Treo 680 Smartphone
My treo 680 is saying it cant read the sim card, but its brand new
You might try cleaning the contacts with some fine 400 grit sandpaper or other contact cleaner. I have a 2 year old 680, and I cut a piece of this sandpaper to the same size as the sim card. I pushed it into the slot, and ran it in and out for half a minute. I also sanded the contacts on the sim. Not too much, mind you, but it cured my problem. Good luck...
Jul 29, 2009 | Palm Treo 680 Smartphone
Vodaphone Palm Treo 650 and when I put my CHIP into
Hi, not really familiar with Plm devices but insert your sim in to the palm go to contacts and look for Copy to sim or something similar. Sim cards have limited memory,varying from 100 to 250 contacts and 30 to 50 sms.Last would be one by one.
Apr 23, 2009 | Cell Phones
Palm treo
If all contacts are on computer, I'd pull out sim card and do a hard reset:
http://search.active.palm.com/?q=hard+reset+palm&x=0&y=0
May 20, 2008 | Palm Treo 650 Handheld
TREO 650
On my device, I simply select the contact or contacts and then select save to sim.
your treo might also have a program for just this purpose.
But I just select the contacts, then hold stulys down untill the menu comes up and simply select save to sim. It can be difrent on your model.
May 01, 2008 | Palm Treo 650 Handheld
Installing the memory card in my Treo 650 cell phone
there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)5deba98.jpg
You can back up your Treo to either your PC or your SD
card. If you back up to your PC via hotsync, then there is a nice freeware which
can be installed to your Treo that is called SyncAll (all one has to do is right
before the sync, open the program and click "force all to sync"), and it will move
all the files, including preferences and such that don't normally get sync'd. If
you backup to your SD card, there are numerous programs for accomplishing this. It
is important that the number of backup-to-SD programs are limited for the Treo 650
due the NVFS file system. You can try THIS ONE for example - it's free.
Apr 26, 2008 | Palm Treo 650 Handheld
W668
This is caused by bad contact between the phone and sim card.
I had the same problem, and I simply put 3 small squares of paper on the bottom side of the sim card tray.  This ensures the sim card keep in contact with the phone at all times.
Mar 13, 2008 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
108 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
