posted by illessence on May 01, 2008
i have a bissell proheat clearview plus steamcleaner. i was using it and then the little red flow indicator stopped spinning and it quit sprayng any liquid. i looked for where it could be clogged but i dont see anything
1 Other User Has The Same Problem
Comment by Guest, posted on May 13, 2008
my only issue is the cleaner (soap) is not spraying out, I the water is and is heated I have tried switching back and forth rince to full soap, no luck.
Solution #1
posted on May 01, 2008
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bissell 1699 ProHeat Clear View
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Bissell 1699 ProHeat Clear View Upright Steam...
i have a 1699 proheat
i have a 1699 proheat upright... Answer This...
Carpet Cleaner
Carpet Cleaner
i was cleaning my carpet and it... Answer This...
replace the switch that...
My carpet cleaner is not... Answer This...
BISSELPRO HEAT CARPET CLEANER
i have taken the top handle... Answer This...
Bissell Proheat
Bissell Proheat
I need help installing a belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
