Windows shuts down
I get a bad_pool_header error at random times using Windows Vista. Any idea why that is happening?
  • 13,433 Answers
Possible causes
faulty ram
you can test your memory with
http://www.memtest.org/
faulty harddrive or corrupt
start -> run -> type in cmd -> type in the black shell - chkdsk c: /F /X if it asks to do it when pc is started next time press yes and restart your pc
bad driver.
recently updated a driver? go back to the old version or get a new version.
Posted on May 02, 2008
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Heater fires and shuts off repeatedly. reads CHF. Has good flow.
error code should be inside heater make shure you have adequate gas pressure also sounds like bad flame sensor when flame sensor doesnt sense flame it will shut off after 7 seconds
Oct 02, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
Laptop randomly shuts down
yeah ...you might have done some shortcuts on the key board ...cause indeed when its shuts down by error ..its shows the blue screen ...and the error...either you hit by mistake a combination ...or ...it was from the power saving mode...or ...from the antivirus scanning ...a presenting to turn of the machine after finished scans...or ..from downloading ..for example utorrent has settings to turn off computer when the download is finished....just whatch it carefully and remember what you was running when t does that
Jul 16, 2009 | Computers & Internet
Sony CRX835E CD-RW drive, Blue screen of Death on inserting CD-R
Bad Norton install. Actually bad Norton. Its causing driver corruption.The fact that it appears only when you insert a cd-r it's just random occurence, it could have happened as well when you would have tried to print something.
Best fix: just get rid of Norton , it's useless anyway. Get a decent antivirus for start. Otherwise uninstall it using the official uninstaller (not by using its uninstaller), run a registry cleaner, install it again using this time a diferent location and hope to gods that this time it won't screw your pc.
May 01, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Feb 26, 2009 | Computers & Internet
Blue screen at Microsoft second security package
Comment by ceryac, posted on Jun 26, 2008 This morning I have started getting the error message Bad Pool Header after my computer has been on line for about 25-30 minutes. RegCure said it can fix Blue Screen errors but it does not fix this.I have no idea why or what to do to fix it.
Regards
Ceryac
Apr 05, 2008 | Xterasys XN-2423G (XN2423G) Wireless...
Computer shutting down randomly in the middle of everything...even offline games
This can be the result of a virus infection or an infection of other malicious software such as spyware.
Run a thorough system scan.
If this doesn;t help, tell me and we'll go to the next thing to check/do for this kind of problem.
Greetings,
DarkNeogen
Jan 25, 2008 | Microsoft Windows Vista Ultimate Edition
My computer shuts down at random intervals, most of the time it happens when a larger program or someting with a large grafix demand is running, but their are times when it will shut off when nothing is...
Hi, Random shut down is usually the hard drive. You need to get it tested at a repair shop and ask if it could be repaired or if you will need a new hard drive. If it's not too big of a problem yet, they might be able to do a lowlevel format which will eliminate bad sectors and do a new install. However, if there's too many bad sectors, it might need to be replaced. Good Luck and let me know what happens.
May 29, 2007 | Intel Gigabyte GA-8IPE1000-G 865PE Socket...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
