Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Don't know anything...wvf2400
My wife and I just moved to Europe and are trying to figure out the washer in our apartment. I know this is int he wrong forum, but I figured my 2400 couldn't be that much different than the 2402.
I think it is a washer dryer combo.
The pull-out drawer thing has a spot on the far left for softener and 2 additional spots for detergent. If we are washing plain clothes, where do we put the detergent (I think it goes in the middle one, but I'm not sure).
I found the power button, but what does the button with the tub thing do (in the middle) and the E button (I think that is the efficient mode).
I think we then set the wash knob to b (we'd use a if we want a presoak). How do we get the dryer to work? Can I wash clothes and not dry them? What if I just need to dry something (like I get caught in a rainstorm)?
Any idea where I can find a manual for the thing?
Thanks. I didn't see a manual, but I never thought about phoning them.
Posted on Jun 14, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Go to the Bosch website and down-load the operation manual. If it's not on the site, 'phone their customer service number and they'll send you one gratis - they did for my WVF-2402.
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
Not enough water stays in machine to cover clothes We know this is an econosaver but wife likes to saok whites in total water Tried adding water by the bucket while washer is stopped but it automatically...
Hello, Thank You for using FixYa. I will be helping you today.There is no way to change the water level. It washes by spraying the water over the cloths as it moves around.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
The tub moves to freely and bangs on the washer sides
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
Jun 10, 2011 | Maytag Washing Machines
Inferred light comes on but can"t see anything the light in side does not come on
In other words, you don't see a green glow in the viewer, hey. IR works, Hunnn ! It could be a number of things but the most common problem with these Russian manufacture binoculars, monoculars, scopes is the image intensifier tube goes south. I said it's the most common but there are other things that can go wrong; such as, broken wire, faulty on/off switch, (here you have one switch for the on/off on the NV monocular while the IR has another switch to turn it on.) I have work on them enough. This is the order faults, image tube with broken wire, faulty switches, none operation ccfl with voltage multiplier
There is a lot of variables involved here, how was it handled, has it been dropped been in water/salt water, kids play with the NV devise, wife throw it at you!, it been exposed to bright lights (tried to be used during the day or at night looking a bright lights)---bright lights will destroy the image intensifier tube...
It will come apart unless you have that is manufacture marine environment then this a totally different problem. Take the batterers out first. Unscrew the lens. there could be some screws/nuts behind the front optical lens. This will release the front half from the back half. Now, if is the way to monocular is assembled. But what ever type of NV and how it comes apart. You'll have figure it out first. Don't take the lens apart, these will mess up the focal calibration. Take the parts and put them in order as the come apart. Now take wire markers and mark the wires. Draw a ruff diagram of the printed circuit boards and label the wire with markers on the diagram. This way if wire brake off you'll will know were each wire goes. Also, remember, wires have a beginning and end, they are attached to something on each end. I wish you lots of luck, stewbison
Mar 07, 2011 | Optics
Exploded view of Berings and washer HELP ME!!! GE WSM2700W
Go to appliancepartpros.com and type in your complete model number. There are some excellent exploded view diagrams of your entire unit, complete with part numbers. Another source you can try is searspartsdirect.com. I hope this helps you.
May 29, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
May 24, 2009 | Washing Machines
Internet connection keeps dropping
That may sound like a "roaming tendency" issue, with your laptop wireless card or settings, and/or general radio interference. try checking and tweaking the advanced settings of your wireless card, and maybe check for outside interference between your computer and router. Many cards have roam settings that dictate how often they roam between APs. I too live in an apartment complex, where other neighbors have their own WiFi router and there can be interference, and "intrusion issues" :? if your equipment is not properly set and secured.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
No spin cycle.
Do you hear if motor is running (an humming noise) ?if you can then It sounds like a badly worn belt that slid on the tub (the washer succeed to spin- depending on clothes weight in tub) . Open the rear panel, check for belt status and if it really worn,replace it with a genuine belt from the manufacturer.
Be aware you should disconnected power cable from the machine before starting work on it.
Come back if you need more help...
Oct 20, 2007 | Kenmore 44042 Front Load Washer
HOTPOINT dishwasher flooding my kitchen floor
Does water comes into the dishwasher all time, even when it doesn't operated?
Aug 07, 2007 | Hotpoint 24 in. HDA3740G Built-in...
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
267 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
