Question about Car Audio & Video
Amp not working
My amp just stopped working it keeps blowing the 100 amp fuse in my main power wire every tome i turn it on, theleds blink faintly and the amp makes a cliking sound, so i opened it up and really checked it over i seen nothing to lead me to beleive that its blown,would you have any ideas?
  • 1 more comment
  • loren_nov May 07, 2008
    my amp is a punch 1000 2 channle thanks for taking the time to answer.
  • Anonymous Jun 26, 2008
    cs800 breker fuse 15a blows when power is turn on
  • Daper07 Feb 11, 2009
    my amp is a ppi pcx 5800 and it keeps blowing a 100 watt main power fuse . Every time i put a new fuse in it pops.
  • 631 Answers
If the fuse only blows after remote voltage is applied, it likely has shorted output transistors.
You should confirm that nothing external is causing this by disconnecting the speaker wires from the amplifier's speaker terminals and disconnecting the RCA cables from the jacks.
What make/model amp is this?
Posted on May 03, 2008
Cycke keeps blowing main fuse
indicator relay assy could be faulty.the indicator stalk could have a broken wire which is causing 2 amp draw.airbag clock spring could be faulty.
Aug 14, 2014 | Motorcycles
I have a 97 galant that keeps blowing the 100 amp fuse? alternator tested good twice checked wiring reads good is there another fuse ?
Usually that fuse powers the alternator and the fuse box.
It would have to be a big short to ground to blow that fuse.
Its possible the main wire to the alternator is touching a metal spot, or the alternator is shorting out inside when it is running.
What is draining the battery may be something else, or the battery could be discharging after the fuse blows if the alternator is not charging it.
Apr 15, 2013 | 1997 Mitsubishi Galant
Main 30 amp fuse keeps blowing when i plug the 4 wire fuse top back on after replacing 30 amp fuse. any suggestions
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
keep blowing the 30 amp fuse
main fuse keeps blowing
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Jul 14, 2017 | 2003 Honda VT 1100 C Shadow Spirit
I have "cooked" (i think)
When the fuses blow like that suspect an overload in either the power supply or main amp stages. I think you might have damaged one or more of the output devices. They can develop faults quick if you're using the wrong type speakers or have faulty wiring to them. The main cause of fuse blowing is a semi-conductor device that is acting like it is a piece of wire. For instance an output transistor when connected to a multi-meter on the ohm scale, will show a full scale deflection, just like if you had touch the two test probes together.
Nov 20, 2010 | AudioSource AMP-100 2-Channel Amplifier
My 2005 honda vt750 shadow keeps blowing the 30 amp fuse at low revs. just kills the main power and stalls. . Can anyone help??
Hi, Rickuniversa before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
Main 30 amp fuse blows when turn on the ignition switch
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Sep 19, 2010 | 2005 Honda VT 750 Shadow Aero
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
PPI PC1400
Since it's an intermittant problem and a relatively expensive amplifier, you should have it checked by a qualified tech. If you keep trying to power it up, it will eventually blow out the power supply transistors which will add as much as $100 to the repair bill.
Oct 19, 2007 | PPI PC1400 Car Audio Amplifier
Fuse keeps blowing when sub volume is turned up
the amp draw rating on the amp is 100 you need to put a larger fuse in, such as a 150 amp, it would be a good idea to go to 0 ga but not needed. you might also want to upgrade your altenator.
Nov 29, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Car Audio & Video Logo
295 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
