Question about Sony Playstation 3 (PS3) Console
My netgear router keepts losing the connection to my PS3 and my laptop. The laptop signal is picked up by a WG111 Wirelss adapter but it still loses the connection. My PS3 has days where it can be good but usually I will experience a lot of lag and connection interupted while playing online. It's no the internet connection as I used to have a D-Link router which worked fine. Is my router interfearing with my television as they are very close to eachother?
  • Anonymous May 02, 2008
    The Best way to fix a problem like this is to use a PS3 Repair Guide.
    You can find a good one here:
    www.PS3RepairsGuide.com
    Problem Solver:
  • 17 Answers
The main cause could be a setting on the Netgear router. Take a look in the networking section on the free ps3 repair guide http://www.ps3guide.info/networking-index
This should answer your question
Posted on Oct 02, 2009
You didn't mention which Netgear router you have. Customers of Netgear have reported problems with the WNR854R model. See Maximum PC April 2008.
Posted on May 02, 2008
Netgear zing
This is a wireless adaptor not a router.
Check out the internet connection by directly wiring into the LAN port of the router to the PC.
You will probably find the fault there and have to consult your ISP.
If it is the adaptor, check you have the correct driver software and the distance between the computer and the router.
Apr 25, 2014 | NetGear WG111 802.11g/b Wireless Adapter
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 doesn't see D-Link DIR-655 wireless network
Hi Joe,
I would suggest you to change the wireless channel on the Dlink and use the channel on which WG111 will scan and connect to your network. Also, plese make sure to use the security encryption on the DLINK to WEP or WPA only. Using higher security like WPA2 will cause issues with this adapter.
Regards
Anand
Jun 21, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NETGEAR WRN 2000 - WG111 keeps scanning
i try to dowload the driver for a wireless usb adapter wg111t only one i see his detective one
Oct 07, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Stupid router
SUE NETGEAR PURPOSE OF WIRELSS ADAPTER IS TO CONNECT WIRELESSLY, IDIOTS
May 26, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Internall wireless adapter not working
Have you configured the router to broadcast the SSID? In other words, can the 2nd computer (Laptop?) pick up the the router and see the wireless name of the network? or does it not see yours and just other people's down the street?
May 10, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Connection problem
if it's going offline, then it's losing the signal, or is recieving a low signal, it should be at 54mbps but when it gets below around 24mbps, it will disconnect and look for a stronger connection in your area, or disconnect from the net altogether.
Put your router in a higher and better line of sight to your adapter, walls and floors can block the signal and check that it's not your router that is losing the connection.
Oct 16, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
