Philips DVDR3570H HDD DVD player Recorder - done basic set up last night but the start up search for analogue channels returned 0 - speant 2 hours re arranging plugs & it still wouldn't locate them? do we need to find them to operate
  • 476 Answers
The DVDR3570H will only find analogue channels if you have a TV aerial connected to it.
If you only have a satellite or cable box, then you can still use the recorder, but you will have to use the AV inputs on the recorder. In this case you will only be able to record the satellite or cable channel you are watching.
Posted on May 02, 2008
Ihave philips hdd/dvd player/recorder dvdr3570h/dvdr3590h wehave just had the digital tv switchover but we canot record tv progra
read the instruc. manual since they have information about this matter, if you can or NOT. go to the section troubleshooting for to see and fix it.
God bless you
Sep 27, 2012 | Televison & Video
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Nov 08, 2009 | Panasonic DMR-EH57 HDD Recorder Player
Phillips hddvd5520H recorder
found out was not compatible so returned to store
Dec 19, 2008 | Philips DVDR520H DVD Player/HDD
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Phililps DVDR5570H only plays zone 4.Is there an unlock code for multizone playback?
Try this:
Models supported:
DVDR3570H
DVDR3575H
DVDR3577H
DVDR3590H
DVDR3595H
DVDR3597H
DVDR5520H
DVDR5570H
  1. Power on the recorder
  2. Wait for player to initialise.
  3. Press [HOME] on the remote control.
  4. Press [PLAY / PAUSE]
  5. Key in 1 5 9 1 2 1 2 1 2 0 0 5 2 5 5 – The numbers will appear in the display of the recorder.
  6. Press [PLAY / PAUSE]
If the recorder goes into browser mode during the procedure, then it will need to be re-started from the beginning.
If at any point the recorder is reset to factory settings, then the procedure will need to be carried out again.
Jul 27, 2008 | Televison & Video
Philips DVDR3450H Recorder does not record all of timed programs
When setting the record timer make sure that PDC / VPS is switched OFF.
PDC - Programme Delivery Control / VPS - Video Programming System is designed to allow for late starting or running programmes. Not all channels support PDC/VPS, so the recorder may be waiting for a PDC/VPS signal which isn't there.
Jan 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Problems with guide plus
guideplus is for analogue tuner only,you should use digital guide
Jan 04, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
Electro Med Services...
