Hi, i have a panasonic SC-HT730 system that uses the subwoofer SB-WA730, and somebody steb in the back cables and broke the PCB, to make this worse, a small PCB part is missing. So im looking dor the schematics to make the proper conections in the pcb. I do appreciate any help. Thanks !
    Scholar:
  • 131 Answers
Here is the phone number to get schematic it is a great number to have it is panasonic direct parts ordering for tvs i hope this helps 18008339626
thanks doctor video
Posted on May 01, 2008
I have a Panasonic home theater sound system model# sa-ht730 and there is not a place for any power to go
That's because it is not a stand alone system. In fact the power goes into the subwoofer box and then a cable feeds from that to the unit into the smaller of the sockets on the lower left of the picture.
You can download the full user manual here!
http://shop.panasonic.com/support-only/SC-HT730.html
Apr 25, 2016 | Panasonic Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Mar 26, 2010 | Panasonic SC-HT730 System
Hi, advice me where I can find the system cable for an SC-HT900?
the system cable you are looking for is called: K1HA25HA0001 If you google it you'll get a number of places where you could buy, including ebay but their not cheap, hope this helps
Aug 19, 2009 | Panasonic SC-HT900 System
How to connect pc to Panasonic SC-HT730 home theater system?
From what I can tell from your manual, you do not have auxiliary audio inputs on your system. You can, however, use the TV audio input for sound from your laptop. You will need to purchase an adapter cable that goes from male 1/8" stereo mini plug on one end (your computer jack) to a split (Y) male rca type jack (two connectors for R&L inputs on system. Then you'll need some length of 1/8" male to female miniplug extension cable. You can use the miniplug speaker jack on your laptop as an output.
Of course, if you're using the TV audio inputs, and don't want to unplug them to plug your laptop in, you'll need another pair of splitter cables for those rca jacks on your system so you can plug two different pairs of input devices into them, but I'd try to avoid this scenario if possible.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 16, 2009 | Panasonic SC-HT730 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Panasonic dvd player for subwoofer
I have a SA-HT 690 system with a bad SB-WA342 sub. I can sell you my player or buy your sub.
Oct 29, 2008 | Panasonic SC-HT730 System
Possible broken speaker
You must determine if subwoofer amp or speaker are bad.Take the good surround speaker and move it to the bad side.If the good speaker does not produce audio the the amplifer is bad.If you use the good speaker in either surround output and it works then your speaker is bad.If you take the small speaker apart the panasonic part number is stamped on the magnet.Locate a service center that will order it for you.
Mar 13, 2008 | Panasonic SC-HT730 System
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
