Question about Electronics - Others
Dvd rw i went to novatec and bought a new dvd-rw. i have tried to fit it myself but it is not working. i swapped the wires from my old dvd rom drive over and wondered if i was missing anything. when i look on my computer it says i have a dvd rw but as soon as i try to use it the driver turns to a cd rom sign. please can you help
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Can you tell me what brand/model of drive you got, and is it external or internal? Also, if it came with a CD for installation, was that run? It is likely that you need a new driver for it, and if you can give me the exact information, I could assist in locating the driver if you need further help. Thanks for rating FixYa!
Posted on May 03, 2008
The dvd rom doesnt starts it doesnt even lights the green bulb.
Sounds like the power lead at the rear of the dvd drive has come loose or is faulty.
You will need to open the pc and check that the power lead is fitted correctly, you may need to try another plug, you may have a spare you can swap it with.
Jul 05, 2010 | LG GCC4521B CD-RW/DVD-ROM (Combo) Burner
Tip
Upgrade CD/DVD ROM to CD-RW/DVD ROM
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
on Apr 13, 2008 | Toshiba Satellite 1805-S253 Notebook
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I have a dvd rom and wish to swap it to a dvd rw.
No. Unfortunately. Different manufacturers use different interfaces internally for their drives. Even different drives from the same manufacturer cannot be "swapped" in this manner.
I hope this helps.
Oct 23, 2009 | Computers & Internet
-DVD Drive won't read or burn blank -DVD media
Just replace the drive, that unit is old and it has a bad reputation.
Mar 03, 2017 | Computers & Internet
Compatible internal dvd rom for Toshiba Satellite A215-S4807
You can use almost any laptop cd rom, cd/rw, cd/rw-dvd rom, dvd rom, or dvd/rw that you can find. You might have to transfer the mounting pieces from the old to the new, but that is no big deal.
Should be able to find a used one for in the $20 to $30 range.
Mar 13, 2009 | Toshiba Satellite A215-S4807 Notebook
DVD drive help for Dell Dimension 3000
call DELL support and explain to them, they have send your the wrong type, what you have is IDE, they have send you the ATA. which the motherboard can connect.
Jan 09, 2009 | Dell Dimension 3000 PC Desktop
Replacing DVD/RW-R drive on HP ze2000
very simple, just remove the casing then disconnect the wires from power supply colored yellow,black,red (connector) to dvd rom, then disconnect the cable ribbon to dvd rom unscrew the dvd to the casing then slide out the dvd rom backward( if you are facing the cpu) bfore you install the replacement, you need to check your dvd rom which you have taken out and compare the jumper orientation to your new dvd rom. if the old one is in cable select or in primary or in slave just follow the old one. now if you are finish checking the jumper orientation, you may proceed in installing your dvd rom on casing, install back the screw on bothe sides and all the connectors. power on thats it your finish just proceed to the my computer and check if this appears in it or in the device manager. i hope that this helps you, any questions or clarifications feel free to ask me.
Nov 22, 2007 | Computers & Internet
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
