Question about Canon ImageRUNNER 330s Copier
FOLLOW UP HOW DO I GET IN SERICE MODE TO CLEAR EOOO CANON IMAGE CLASS 2300. THANKS
  • PRAL May 01, 2008
    REQUEST A REFUND INV# 58863
  • PRAL May 01, 2008
    DID HELP AT ALL
    President:
  • 2,712 Answers
Well, unfortunately, this a secret kept from others by Canon. They dont even have it on their service manual. But do call the number I posted. Canon support are very friendly and will walk you through the steps.
you can call them at 1-800-828-4040
And a sincere request, please change the fixya rating that you gave to the other bloke who did nothing but do some time wasting measures to keep his solution as #1. I would appreciate it if you assigned that to someone who really gave you some lead to go on.
Cheers!
irishDruid
Posted on May 01, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    PS, why did you rate this inappropriate? That negative rating is only reserved for posts that are totally irrelevant to your question. I was trying to assist you here, and gave a number you can call to get the code.
    At least dont rate it at all if you are unsatisfied with my response.
    I was just trying to help you with the only recourse available. I would greatly appreciate it if you undid the "inappropriate' rating and dont rate me at all. This is after all a direct request that you made..
  • Swilin Sampson
    Ok, latest info..Apparently you can try to reset by pressing switch 301. On the left hand side of the copier there is a small 2" x 3" door lower
    rear with one screw. Inside is the side view of a PCB where the switch
    is, and various other adjustments.
    Now I am not too sure exactly where that switch is, but if you take a look, you should be able to find it.
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. release RESUME (while still holding down the POWER)
    3. press RESUME twice, then release POWER
    4.
    The green light will blink and the printer will make some noise. Wait
    until this is finished, you are now in the printer's diagnostic mode.
    To select one of the functions below, use the RESUME button and then press POWER to execute:
    # of RESUME Presses - Light Color - Function
    0 - green - Power Off
    1 - orange - Service Test Print: Extended nozzle check pattern
    2 - green - EEPROM information print
    3 - orange - EEPROM initialize
    4 - green - reset waste ink counter (For the Canon waste tank full error)
Machine will not do anything. says system error EOOO. what do i do?
E000 is an error for fuser related problems. the error history indicates any of the following error codes 4 times E001,E002,E003. Action : clear the error Execute #4 printer reset under #7 printer in service mode to clear the error, then off and back on the power.
Apr 16, 2010 | Canon ImageRUNNER 1670F Copier
How do you get into service mode on canon MF6560 (image class) ? Thanks RD
Press “Additional Functions”, “2", “8", “Additional Functions” in succesion.
Display will show “#SSSW”.
Press “+” or “-“ key repeatedly to go through the following menu list:
#SSW, #MENU, #NUMERIC, #SPECIAL, #NCU, #FAX, #SCAN, #PRINT, #NETWORK, #CODEC, #SYSTEM, #ACC, #COUNTER, #REPORT, #DOWNLOAD, #CLEAR, #ROM, #TEST MODE
Don't make adjustments in these modes unless you know what you are doing; could mess things up. Counter mode is especially helpful though for observing the performance (totals, mode, feed, and jam counts).
Jan 11, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Printing issue
If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
Sep 13, 2009 | Canon ImageRUNNER 330s Copier
My canon read error e000 105
go into service mode -function-clear-error- take machine off -un plug from wall -reconnect- turn machine
Dec 05, 2008 | Canon CLC 1120 Color Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
System Error Code
EOOO is a heater error. Could be something damaged and could be that it just need a reset. How to reset depneds on the model.
Jun 10, 2008 | Office Equipment & Supplies
Canon Image Class printer
Have you tried this one that Canon has on their website:
Issue: ERROR LCD: System Error E000
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Jun 09, 2008 | Canon imageCLASS D760 All-In-One Laser...
CANON IMAGE CLASS 2300-EOOO CODE
HI,
Can you please give the make and the model no.
May 01, 2008 | Canon ImageRUNNER 330s Copier
Error code E000 on a canon imageclass D761
in service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
Apr 02, 2008 | Canon imageCLASS D761 Copier
System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
May 07, 2007 | Canon imageCLASS D860 All-In-One Laser...
93 people viewed this question
old marine
old marine
