Question about Acer AL1715 17" LCD Monitor
Acer al1715 Hi, shortly after the flat panel and pc has been switched on, it turns off completly ( including power light) and will not come back on intill the power has been switched off at the plug for a few mins. Please could you help.
  • mickschnee May 02, 2008
    my acer AL1715 monitor also shuts down constantly.After several restarts of the monitor it will stay on .Sometimes for a few minutes or sometimes for an hour or so. Whats up?
  • 472 Answers
Failing capacitors in the power supply will cause this problem and it's fairly common accross all brands.
The parts are cheap, but the labour costs can be high.
If you cannot do this procedure yourself, and also understand the dangers of the electronics, then call several TV repair shops in your area to get a quote, you maybe surprised how much the price can vary.
Just advise them you need to have the capacitors on the power board replaced. It will help them give you a more accurate quote.
Posted on May 27, 2008
My husbands monitor keeps switching off
I had this exact same problem. The monitor kept switching off shortly after turning it on. I found a shorted capacitor (1000uF 10V) in the power supply. Replaced that and now it works fine.
Oct 30, 2010 | Acer AL1715 17" LCD Monitor
Is black
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 22, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
My Acer Al1715 monitor does not display a picture the power is fine as the green light flashes but no picture at all
The light should come on steady. Your monitor most likely has the typical failed capacitor problem. The Power Supply board in the monitor most likely has some capacitors that have failed, visible signs include swelling of the ends of the parts, but they can fail without showing any visible sgns. Replacement of the capacitors often restores operation.
Feb 02, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
My Acer X263W will power off during the reboot of my PC. I cannot power it back on unless I switch off both my pc and monitor for at least 2 minute. How can I make my X263w power on again without turn off...
Your PC monitor may be a CVT type. Anythingwill switch off when a monitor powers on. Its initial kick off current is very heavy and thus sucks in all the current from neighboring devices (your Acer X263W included) and renders them powerless. The only way out is to put the PC with its monitor and the Acer on different power sources (sockets) so that they do not interfere with each other's power requirements.
Dec 18, 2009 | Acer X263W 26 in. LCD TV
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
May 01, 2009 | Acer AL1715 17" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Monitor turns off
Since the green light is going out the monitor's power supply could be the culprit. That popping sound is not good. I would replace the monitor all together.
Jun 03, 2017 | Acer AL1715 (Black, Silver) 17" LCD...
Acer al1711
Hi.  I have no experience with an AL1711 but this sounds very much like the power supply problem that affects the AL1715.
If you understand electronics then you need to check the power supply for faulty components (there were two faulty capacitors in my AL1715).  Replacements should cost about 10p each and however much time it takes.
Unfortunately if you're not into electronics then there's really not much you can do.
If you do take the back off then please post whether you can see any faulty components.
Aug 05, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Acer AL1715 - insufficient brightness
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Feb 02, 2008 | Acer AL1715 17" LCD Monitor
Will not close down
These monitors go into a standby just incase you are only restarting the PC.
To turn it off properly, hit the power button on the monitor before Windows has completely turned the computer off.
IE: tell Windows to shutdown, when you see the blue screen telling you Windows is shutting down, turn it off then.
Hope that helps
Oct 20, 2007 | Acer AL1715 17" LCD Monitor
Acer AL1715 17" LCD Monitor Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
