SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sure
Some SD cards have a little lock on them, you need to take the SD card out of the camera and verify there is not a lock enaged, if there is nto then the camera is the issue, or the memory card.
1. Take out the memory card
2. verifiy its not locked
3. if its not locked try to format it
4. if it does not format that is your issue you need to replace the card.
Thanks I hope this free answer helps if not you might need a camera shop. please do not shoot the messenger. Do not forget to rate the answer before you leave, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
