Question about SanDisk Sansa Clip MP3 Player
Help please did you plug yours into another computer first? or did it just stop working.
  • 8,596 Answers
Either could be the case - these are among the worst players ever made.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
Hello, today i was watching a film on my computer when all of the sudden one of the speakers stopped working. i tried re-plunging the wires into the main speaker, when all of the sudden another speaker...
this is all i could find at the moment about speakers not working..if this does not work go to the link i sent you..
If you are running Microsoft Windows, make sure the speaker setup is correct by following the steps below. Select Hardware and sound or just Sound in the Control Panel window. In Windows XP and older, click Manage audio devices under Sound. On the Playback tab, select your speakers and click the Configure button.26 Apr 2017
Computer speakers do not work - Computer Hope
https://www.computerhope.com/issues/ch000034.htm computer speakers stopped working Google Search
Oct 23, 2017 | JBL CREATURE II Computer Speakers
My battery has stopped charging, on the taskbar it says "plugged in, not charging" Help!
It seems like the battery is plugged in but it is not working.. Try to install the latest version of BIOS for your computer from the computer manufacturer website... If the issue is still not fixed please contact the computer manufacturer and change the battery.. The problem will be fixed
Oct 14, 2010 | Packard Bell Easy One Silver 2101 Notebook
They stopped working. everything is plugged in. nothing is wrong with the wiring. can you please tell me what's wrong with my speakers?
Is it getting power?
Check your computer's plugged in devices (from device manager) to see if you computer can see your speakers plugged in. If they are, then try updating/installing the latest drivers. If nothing works, your speakers have become faulty. Try checking on a different computer, and if nothing works. Contact your vendor.
May 24, 2010 | Logitech LS11 2 Speakers
My usb ports stopped recognizing my plug in's. They work for power but my wireless mouse and iPhone when plugged in won't work now.
I have a similar problem with my A135-S2286. I noted that the mouse pad area got hot, but I found it was the Wifi card. After getting hot, the computer stops recognizing USB devices and finally the computer gets stuck.
Try turning off your Wifi and please let me know if it works.
Mar 04, 2010 | Toshiba Satellite A135-S2276 Notebook
Portable HDD stopped working and not recognized
Sounds like hardrive maybe bad try on another computer! Good luck!!!
Jun 22, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Speakers have stop having sound
1. Please plug in a set of speakers or headphones known to be in working order.
a. If the known-to-be-in-working order speakers or headphones work, your existing speakers are faulty.
b. if the known-to-be-in-working order speakers or headphones do not work, your existing speakers are fine, and your sound card is faulty.
Mar 29, 2009 | Computers & Internet
Printer's lights wont stop flashing Hp D4260
go to hp support website this is a software problem
Feb 09, 2009 | HP Deskjet D4260 Printer
My web cam
uninstall the software for that camera. then restart your computer. after restarting, re-install the drivers for that camera.
this may work. if this still doesnt solve your problem, try jumping from one usb slot to another.
Mar 24, 2008 | Computers & Internet
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
