Question about Cameras
Format problem useing 1gb card was ok then for some reason I am having the same problems as others on here it asks me to format card then when I press ok says it cant have tryed several 1gb cards no luck camera works ok with out card.
  • tilden55 May 13, 2008
    I put in a 1gb card and had no problems. Then it started to ask if I wanted to format. I dod nothing because I thought I would lose all my pictures. What do I do to get the pictures off the card?
Check if the SD card seems to insert properly. If not, the pins could be crushed in the SD card holder. That's what happend to my camera. So the camera will work fine without an SD card but I can't install a card. The other possiblility is that the card is incompatiable, but if the card was working before (and not in the locked position) that's not the issue.
Posted on May 15, 2008
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
Format 1 GB memory card
Hello Myrna,
You do not need to set the size as the camera automatically "sees" it. So when you see 970MB that is the size of the 1GB card after formatting as the formatting process uses some of the memory. So just go ahead & press OK followed by "function set".
You can download the manual from the link below:
A530 Power Shot
From the manual:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 08, 2008 | Canon PowerShot A530 Digital Camera
My sandisk 1gb card was in my blackberry curve and i turned it off and took the battery out before it shut all the way down and when i turn it back on i got a error saying the media card was not formatted...
look in your menu there should be a section for the card that will ask if you want to format the card. or can you take the blackberry back to factory restart, that should format the card, I know it does in my camera.
Oct 03, 2017 | SanDisk 1GB microSD Memory Card
Can't format sdhc card in my camera.
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Mar 04, 2009 | SVP CDC-8610 Digital Camera
MMC Problem in 6230i
Can any one tell me why there is a code on every card i insert in my 6230i. Its not same i other 6230i of my friends.
Jan 26, 2009 | Nokia 6230i Cellular Phone
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
1gb crad
have you tried the formatting function of the camera?
Press the set button to open the configuration mode. Select “Format”, press the OK button and select “YES” to start formatting.
The menu is displayed again after formatting.
Dec 10, 2007 | SVP DC-12D Digital Camera
I have the same problem as 'Can't acces [sic] mass storage'
Problem is unit will not work with an SD disk over 512MB. For some reason if the SD Card is 1GB or larger you will receive the message the card needs formatting. Verified this after many hours of trying to get 1 and 2GB cards to work. Used 512MB cards or less and the camera works perfectly. Originally got this info from a tech support facility that does support for Bushnell.
Aug 06, 2007 | Bushnell ImageView 11-8321 Binocular
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
