Question about Samsung SP42P2S Television
Samsung sp42w5hpx my samsung tv is shawdoring in the red & green and is off set with the coulor can you help with wots wrong with it .its like the red bulb has droped down and not centrel thanks
  • Anonymous May 30, 2008
    i have samsung sp42w5hp rear projection crt. there is ghosting of blue in wave form across the screen. sound ok.
I have same problem. Can any one help please.Matt.
Posted on May 21, 2010
I have a Samsung 55" LED TV (un55es6100) and the red color is flaring up. Green/Blue are perfectly normal. All other tv functions are normal. Can someone please help me figure out what to replace?
Are you using component cables or HDMI? If component, make sure your red, green and blue are pushed in all the way. Too, make sure your red audio is not the red video. If hdmi is used try a new one. If these do not help unplug your t.v for 10-20 seconds and plug it back in. All else fails reset your t.v to default factory settings.
Apr 04, 2017 | Samsung Televison & Video
Ive got a samsung LE32A457CID tv every now and then whilst watching a progamme all the people green, wot can this be ???
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Good luck and if you still have the owners manual, You should read up on the convergence section in the manual.
Jun 14, 2010 | Samsung Televison & Video
XBox Audio Problems
The red, blue and green are ONLY the Video outputs, and connect colour to colour, now, there are Two other connections, again coulor to coulor, usually red & white, that hook up to the Stereo INPUT. So you need BOTH sets to work IE: The Video & Audio. Video: Blue, Red, Green. Audio: Red & White.
Jan 20, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The bulbs have gone on the heater settings in my toyota corolla 2000 1.3i se an i would like to change all bulb colors in the interior,is this possible? thank you
yes you can change these by removing the facier trim very gently and removing the push in type bulbs availible from you local toyota service department. as for the different coulors you are limited by whatever coulor cover for the globes you can find i know there are green , blue, yellow and red
Dec 09, 2009 | 2005 Toyota Corolla
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I hear sound but no picture!!!!!!
If your using dubbing wires to connect to tv then check or replace the video input wire
Aug 28, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Green out of alignment on samsung rear projection tv
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
Connection
Hi...there,
Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
Feb 02, 2009 | iiyama Vision Master 404 Monitor
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Samsung SP42P2S Television Logo
185 people viewed this question
Henry  Thomas
Henry Thomas
