Question about Dell 924 All-in-One InkJet Printer
Paper jam problem
Hi, I have the exact problem as you do..any idea how to fix it?? thanks, sarah.
    Scholar:
  • 41 Answers
Hi, if you are having the paper jam issue , then unplug the power adapter and remove all the papers from the paper tray and if you closely look inside the input paper tray you will find rollers , move the rollers with your finger tips. open the printer cover to the extreme left you will find the cartridge holders , move the holder from left to right a couple of times , behind the cartridge holders you will find a transparent strip which is inch wide and is inch wide and firmly connected at both the ends, use a damp cloth and clean that strip . lift the printer an#d shake it firmly turn the printer upside down and gently tab on the base , look for any obstructions.
Try all these steps and if there is an issue then you have to purchase the new printer.
good luck :), let me know once you perform all these steps
Posted on May 03, 2008
Paper jam problem
Hi Sarah, do you have an epson printer?
In these years i had this problem with a lot of Epson Printers...
Well, if this is the situation, i'm sorry to tell you that this is caused by the printer pick up rollers that are worn, so... you can try to wipe with alcohol the surface of the rollers, but there's no way to fix this...
You can try to gently push the paper inside the printer when it takes the sheet
Dec 08, 2015 | Office Equipment & Supplies
Hi im having some problems my aunt just gave me her lexmark 1250 and the paper keeps jamming i think i have that fixed but now i go to print a test page to see if its working and all i get is a flashing...
The flashing power light could be to a faulty cartridge or the cartridge carrier has stalled. Follow the steps below to fix the problem:
  1. Open the printer cover.
  2. Ensure there is no jammed paper in the cartridge area and the cartridge carrier is free from any obstructions (any foreign objects or debris)
  3. Remove both cartridges from the printer.
  4. Close the printer cover.
  5. Unplug and replug the printer into the power source to reset it.
  6. When the printer turns on, re-insert 1 cartridge first. Close the printer cover.
  7. Check the light pattern on the power. If not blinking, open the printer cover and re-insert the other cartridge.
  8. Replace whichever cartridge is causing the power light to blink.
Hope this information has been helpful.
Jul 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
While removing a paper jam a white plastic piece fell into the paper feed area. It appears intact, but I cannot work out how or exactly where to re-attach it. The printer cannot feed the paper correctly...
This white plastic pease is from Paper Out Chut, There are two latch to fix it, If you can , Other wise you have to open the cabinet and than only 'you can fix it.
May 02, 2010 | Brother DCP 165C Compact Color Inkjet...
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
HP Officejet 7310 AllInOne. 1.Had paper jam, carefully removed jam. (happens from time to time no prob). 2. Prob - after this latest jam, paper feeder no longer works properly. 3. When printer feeder takes...
There is idea.. Vernee decision. Every time, when аa paper stuck you its remoove most often aptly. However this trouble meets in printers HP((. Prizhimnoy roller of the presenting the paper has distorted, he came out of its place or axis of the roller or rubber roller, be brake platform cost(stand)s not exactly, this that platform that under roller. Nothing else be can not. Thank you that so have well described the fault. If you to manage most see the jaggy of the roller of the presenting the paper, you understand, there all very frail and such could happen, Else brake platform from below under spring - this spring stress in platform from below on the centre exactly or two springs then they cost(stand) in symmetry, you it is necessary пробывать press on brake platform and come to a conclusion, has she even striking on the centre. Thank you
Sep 11, 2009 | Sharp AL 1631 Copier
Paper jams in Lexmark X4270
Mine is doing the exact same thing and I need to know how to fix it, I am expecting some very important paperwork and I need the fax machine working!
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
23 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
