Question about Canon ImageRUNNER 330s Copier
NEED CANON IC 2300 EOOO RESET CODE
NEED RESET CODE FOR IC 2300 E000
  • PRAL May 02, 2008
    I TRYIED MANY TIMES TO GET INTO SERVICE MODE I WAS UNABLE TO. THANKS FOR TRYING . I SPENT A LOT OF TIME WITH EVERYONE. I KNOW YOU AREN'T ASKING MUCH I STILL WOULD LIKE A REFUND INV#
  • Canon Expert
  • 287 Answers
Hello PRAL,
I will gladly try to help you, but please understand that E000 is a fuser error code and can either be an anomaly or if it is genuine the code will return almost immediately because of safety reasons( high temperature control ). Please forgive me if I over - explain things but I don't want to take it for granted that you are familiar with how to enter and navigate service mode, since that is indeed what you will have to do. To reset the code you wil have to enter service mode. To do that you will need to press the "ADDITIONAL FUNCTIONS " button and then the numbers 2 and 8 at the same time, then press the "ADDITIONAL FUNCTIONS" BUTTON again. A three step continuous flow procedure. Additional functions, 2&8 together,additional functions. This should bring you to a new screen that will have several new tabs not normally seen. One will say "COPIER". Press it. New screen again.The main screen will have several options but we will be using the "TABS" you can see across the top of the display. One of those tabs says "FUNCTION". Press it. New display again. Look in the main display and you will see an item that says "CLEAR". Press clear. New display again with a list of items that you can "clear". Press "ERR". Once you have done that, locate the "OK" tab at the lower right hand corner of the display and press it. You just reset the code. Now turn the copier off using the MAIN POWER SWITCH. If you are in doubt as to where it is located (not the button you see on the operator control panel) then unplug the machine for about 5 seconds. Then plug it back up. The copier will begin its warm up and self diagnostic check as it attempts to become"READY" again. Somewhere between the start up and making your 1st copy, the copier should display a similiar error code if the problem is genuine. If it was just a burp before then you may be ok. Fuser codes can be generated for several reasons other than a true problem. But if you do have a big problem, the copier will rather quickly display the error code again. At that point you will need service. I know for sure that I have provided you with exactly the information you requested, which was to reset the error code and I hope the reset is all you need to return to copier bliss. I hope you have no additional problems. If you don't mind would you please return to the "FIXYA" website and provide positite feedback to them as I have helped you. Thanx and good luck to you and yours.............SPINAL..........
Posted on May 01, 2008
E000, Canon IR1600, help
The main motor malfuctions code.Please check the development unit ,transfer unit and the fuser unit drive.The problem is mechanical.
Aug 20, 2009 | Canon Office Equipment & Supplies
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
System error E000
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Jul 07, 2008 | Canon imageCLASS 2300 All-In-One Laser...
System Error Code
EOOO is a heater error. Could be something damaged and could be that it just need a reset. How to reset depneds on the model.
Jun 10, 2008 | Office Equipment & Supplies
Canon Image Class printer
Have you tried this one that Canon has on their website:
Issue: ERROR LCD: System Error E000
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Jun 09, 2008 | Canon imageCLASS D760 All-In-One Laser...
CANON IMAGE CLASS 2300-EOOO CODE
HI,
Can you please give the make and the model no.
May 01, 2008 | Canon ImageRUNNER 330s Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
272 people viewed this question
old marine
old marine
