Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Poor suction...continued Wow, thanks for answering so quickly! To answer your question, yes, there is suction at the screen, but it is very weak. I keep that screen clean. As a side note, I noticed that when I remove the top clear plastic cover (that would be part # 37 on the diagram, as far as I can tell) there is decent suction coming from the intake there--part 36? 30? it's hard to tell. But with the cover on, I feel no suction (from where it sucks up the water directly from the carpet), no matter how many times I reseat the cover. The white/clear seal seems intact and seated correctly, and I cant feel any leaks. I'm at a loss! Yesterday I did the carpets, using 3 tanks of water total, and I only sucked in 3/4 of a tank...the carpet is still wet!! Any ideas? I really appreciate your vacuum philanthropy, thanks again! Eve
    President:
  • 1,673 Answers
Wish I had it in my shop, it is hard to figure your problem. I do know that you must have something out of place and you may have to take it apart to find it. You may feel some suction there at the top of the clear nozzle, but maybe it isn't strong enough to pull anything up, but you may have a problem witrh it not seating all of the way on both sides, and you ,maynot feel much there anyways. Check at the bottom where the tank sits. is the seal ok. With the tank off, is there alot of suction at the filter screen? If there is, then the problem wouldn't be inside. Is the hose door on the back closed tightly? How old is this unit, if less then a year, then it is under warranty. There is an automatic shutoff for suction when it senses that the tank is full, maybe the problem is there. I believe it is the float inside the tank.
Posted on May 01, 2008
No suction
Very little suction at the source, inlets, or at he hose?
Your answer will vary depending where the power loss is felt; most likely something clogged in the hose or one of the inlet pipes.
Help me out with more info and i'll do my best to lead you to a quick resolution.
Nov 09, 2013 | Broan-NuTone CV352 Performance Central...
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Jul 20, 2010 | Dyson DC21 All Floors Stowaway HEPA...
Very little suction? Someone give me an answer please.
You must have something obstructing the airflow. There is sometimes a small trap door under the vacuum where the brush is located. Open that door and see if there is something jammed in it. If you don't have the door, then there is an obstruction somewhere in the vacuum. You should also look in the hose.
Jim
Jun 10, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Poor suction
Either you have clogged filters, or the motor is weak, you could check the carbon brushes, otherwise replace the motor.
Mar 28, 2008 | Vacuums
Dysan DC01 No suction
Hi.
Check that the black rubber flaps at the bottom back close the holes in the chasis when you switch on.
Let me know how you get on.
http://dysonmanuals.inc.io/
Chris.
Dec 01, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
87 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
