Coleman Evcon model DGATO70BDC Starts to run then stops?
My coleman Evcon model DGATO70BDC 1994 starts up and then locks out. The pilot lights and then furnace runs for maybe 2-5 minutes and all that is still running is the air chamber fan. I am thinking of just replacing all parts that could be responsible the problem. There's not much there as probably you know. There is no circuit board just basic electronic ignition,relays thermo senors and etc.. Any help would greatly be appreciated. James
  • 828 Answers
What you have is an ignition problem and your unit is shutting down on safety.
Posted on May 09, 2008
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
Coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Feb 19, 2010 | Tools & Hardware - Others
How to replace ignitor on coleman furnac evcon model dgato70bdc i have a new ign and i need to know how much of the front of the furnace i need to remove or what part of the front to remove, the gas valve...
Hi some of these you do not have to remove the burner you just indo the hot surface ignitor its black with ceramic base ? if so you remove the metal cover over the burner and swap it out .
Feb 04, 2010 | Heating & Cooling
I have a coleman evcon and the gas keeps shutting off
The click noise you hear is the magnet inside the valve dropping out. Which means, the voltage that energizes it is low or interupted. Possible, weak pilot flame, bad thermocouple or bad secondary limit switch. This limit switch is located left of the main control. made of ceramic. It can also be a bad gas valve...
Mar 23, 2009 | Coleman Propane Forced Air Heater...
My coleman Evcon model DGATO70BDC 1994 starts up and then locks out. The pilot lights and then furnace runs for maybe 2-5 minutes and all that is still running is the air chamber fan. I am thinking of just...
Does your furnace have an air flow sensor? Blowing out the lowest tube will sometimes clear it and allow your furnace to operate. Lack of differential pressure across the burner will cause a lockout.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
596 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
