Question about Canon ImageRUNNER 330s Copier
CANON IMAGE CLASS 2300-EOOO CODE
REQUEST THE RESET CODE. THANKS PETER
  • 1 more comment
  • PRAL May 01, 2008
    THE CODE ON THE DISPLAY IS EOOO FOR THE IMAGE CLASS 2300. INDICATE FUSER ERROR. I DON'T HAVE THE DIAGNOTICS CODE TO GET IN AND RESET THE EOO. CAN YOU HELP
  • PRAL May 01, 2008
    CANON COPIER IMAGE CLASS 2300. I NEED TO GET IN DIAGNOSTIC AND RESET THE E000 CODE. FUSER ERROR. THANKS
  • PRAL May 01, 2008
    DON'T YOU KNOW HOW TO GET IN SERVICE MODE FOR THE CANON IMAGE CLASS 2300. I NEED TO RESET EOOO CODE. IF NOT I WANT A REFUND. I AM ON THE LINE WITH CANON . THINK I AM GETTING THE RUN AROUND.
    President:
  • 2,712 Answers
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
They do not give out this info and it is quite hard to find.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    Ok, latest info..Apparently you can try to reset by pressing switch
    301. On the left hand side of the copier there is a small 2" x 3" door
    lower
    rear with one screw. Inside is the side view of a PCB where the switch
    is, and various other adjustments.
    Now I am not too sure exactly where that switch is, but if you take a look, you should be able to find it.
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. release RESUME (while still holding down the POWER)
    3. press RESUME twice, then release POWER
    4.
    The green light will blink and the printer will make some noise. Wait
    until this is finished, you are now in the printer's diagnostic mode.
    To select one of the functions below, use the RESUME button and then press POWER to execute:
    # of RESUME Presses - Light Color - Function
    0 - green - Power Off
    1 - orange - Service Test Print: Extended nozzle check pattern
    2 - green - EEPROM information print
    3 - orange - EEPROM initialize
    4 - green - reset waste ink counter (For the Canon waste tank full error)
    Genius:
  • 3,422 Answers
HI,
Can you please give the make and the model no.
  • 5 more comments
  • Priya darshan May 01, 2008
    I need more details on your problem so that i can help you fix it.
    Ok,just give me a min. i'll let you know if there is a reset for this model.
    Ok,got a lot of manual guides which can help you out.Please CLICK HERE and scroll down the page you will see "GUIDES AND MANUALS" there are four different manuals under that you can just click on each of them to view it and you will find the reset..
    Goodluck,
    Please don't forget to rate or accept the solution as fixya.
    And yes you will have to clear it out in the service mode.I hope you will find it in the manual or else you will have to contact canon.
    Canon USA offers a full range of customer technical support* options:
    • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
    • The location of the ASF nearest you for carry-in service at 1-800-828-4040
    • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
    • Technical Support for Customers in Canada at 1-800-OK-CANON
    Well i already told you.You will have to contact canon for that.If you need a refund you can please read our terms.I have copy pasted the refund policy from there
    Refund Policy
    FixYa's Premium Expert services
    (i.e. Premium Assistance Plan and Live Assistance Chat Sessions) allow
    you to consult a professional group of experts in order to find a
    solution for your tech support problem. Although we are committed for
    providing a professional service, in some cases solving your original
    problem require physical repair work. In these instances, we do not
    think a refund should be issued, especially after a professional
    support service person provided guidance and advice regarding your
    problem. A substantial part of the service our experts provide evolves
    around helping to figure out what is wrong with your product, and what
    should be the best possible remedy for it. If you do feel a refund
    should be award for the service purchased, you may dispute the charge
    by submitting a refund request to premium.support@fixya.com
    and a decision will be rendered within 10 business days.
    Try this out it works with most of the image class model..hope it helps ya..
    Press "Additional Functions", press "#", then press the "Right
    Arrow" button till it says, "Printer", then press "Set" then press the
    "Right Arrow" button again until it says "Printer Reset" then press
    "Set" again, the display will ask you "Yes" or "No". Press the "Left"
    arrow for "Yes", then press "Set". Now, unplug the power cord and wait
    5 seconds and plug back in.
    Please do what i said that is the right one for your model too..
    This will fix it..
To reset the E000 Error on a Canon Imageclass 2300 do the following:
Press the "user mode" key, release, Press the "Additional Functions" key, release. You should see a change in the display. Scroll thru items, (using cursor key), in display untill you see "#7 PRINTER", press the "OK" key, scroll untill you see "#4 PRINTER RESET, press "OK" key, scroll to "YES", press "OK" key, (you should see an "*" by the word yes), Turn main power off/on. If this does not reset the machine then you will probably need to purchase a fuser assembly for your machine. Canon Part# FG6-8325
Hope this helps,
Printdoctor
Posted on Dec 09, 2009
D-link router model:DIR-655, laptop loss wireless signal , not able to connect router and computer: also not able to reset the password. Thanks! Peter
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Then anything Peter did will be erased and you can set-up your router factory fresh.
May 08, 2011 | D-Link DIR-655 Wireless Router
Unable to move files from Files to the screen.
Thank you for your prompt reply to my request.  I have decided that the blocked files are too complicated to sove by  telephone and have, therefore, sent my PSION S3c to POD Ltd in the UK.   Regards, Peter Whiteley (uncle peter)
Apr 05, 2009 | Psion Series 3c
Autodesk autocad 2006 activation cade
i have lost activation code for autocad 2006
Mar 13, 2009 | Autodesk AutoCAD 2006
Child seat in front
yes,go to your dealer,request to disable passenger air bag
Feb 25, 2009 | 1997 Mercedes-Benz C-Class
Cannot access System Programming Mode
You need to get the ''installer code'' in order to get deeper into programming.
Thanks,
lucus123
Feb 15, 2009 | GE Security Simon 3 Wireless Home Security...
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
Jun 29, 2008 | Coby DVD-755 System
W850i
The default security code for Nokia is 12345
IMEI: 352826018904245
Master code: 3036741103
Take your SIM card out first.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (anything) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
Apr 29, 2008 | Nokia N73 Cellular Phone
W859i
941 people viewed this question
old marine
old marine
