Question about Hotpoint Aquarius WF215 Front Load Washer
Hotpoint WF740 Washer
Once washer is switched on ready to do a cycle, it starts to fill up with wather and the an error appears on the LED - F-07 - what does this mean
  • 487 Answers
Than means your heater relay is stuck and you either have to service it or........... repair it your self
HERE you can buy the parts you need or you can locate an other dealer online with google.
Posted on May 01, 2008
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How do i fix mo hotpoint wf740 when it says test
turn the machine on while pressing the on and start buttons at the same time until dOFF appears
Aug 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF215 Front Load Washer Logo
111 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
