SB speakers error
I have a pioner VSX-917V. I hooked up my 2 front speakers, center speaker, 2 back speakers and a sub.
When I do the auto-mcacc. The test tones come out of all the speakers, but then it takes me to an error screen and says there is an error with the SB speakers
  • 1 more comment
  • Anonymous May 22, 2008
    I have the exact same problem. I´ve googled it and also sent the question to Pioneer. The answer i got from Pioneer was that the MCACC needed the SB speakers to be closer to the mic than the frontspeakers and if that didnt work the mic could be broken???
    The things i´ve read on internet is to check the cables so the polarity is correct, + to + and - to -. Some have also said to change the cable connections to "surrond" instead of "rear". (If 7.1 system)
  • DaVision May 22, 2008
  • Swantanamo Dec 26, 2008
    I have the exact same problem as well and I haven't gotten anything to work, it doesn't make any sense, the rear speakers make noise but it comes up with an unexplained error.
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
Posted on Jan 11, 2009
Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
Nov 22, 2017 | Pioneer Audio Players & Recorders
Pioneer VSX-72TXV wont power up. mcacc light just blinks.. unit does not have a video 2 button on the face.
try holding the "TUNE -" button and the ZONE 2 on/off button and see if it turns on. If its turns on, but turns back off again, you either have a problem with your speakers (try disconnecting them) or there is a problem with the receiver that needs to be repaired.
Dec 06, 2013 | Pioneer VSX-72TXV Receiver
Vsx-815 sb. system
Check in your speaker setup menu. Sometimes you can select between using the surround back speaker jacks as "B" front speakers as well. You would have to tell the unit which one you want to use it as.
Feb 08, 2013 | Audio Players & Recorders
Only two of my speaker channel's work when I hook my speakers into it, and one of those two only powers some of the speakers in my Infinity Beta 50. The surround sound channels do not work either. only the...
You have to configure it first. Make sure you follow the instructions on page 5 of your manual to run Auto MCACC Setup which tests the acoustics of your room, speaker size, power level, etc. This is necessary before it will enable you to use surround sound.
Apr 13, 2011 | Pioneer VSX-72TXV Receiver
Auto MCACC Screen Appearing
It would appear the unit thinks your McAAC microphone is inserted. Is it?
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
Jan 30, 2011 | Pioneer VSX-1019AHK A/V receiver
I have a Pioneer VSX-917V. After using it for a couple hours and everything working good, the center speaker quits working. I can reset the unit, re-ajust all speaker settings to my prefrence and the...
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
Dec 26, 2010 | Pioneer VSX-917V-K Receiver
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
Dec 22, 2010 | Pioneer Elite VSX-9100TX Receiver
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
612 people viewed this question
 Grubhead
Grubhead
