Question about Alpine MRV-F345 Car Audio Amplifier
Alpine Amplifier Cuts in and out on Passenger side while driving
Hello, I have an older Alpine MRV F353 V12 amplifier in my car and when I am driving the passender side (both the front and rear speakers) cuts in and out occasionally. I verified all the connections but vibrations do cause the problem. What would be the problem and is the amp even worth fixing? Thanks Alpine MRV F353 I've installed in a Diamonte and with ignition on acc it works fine. But after I start the car is dies out after a second or two. Ant Ideas what could be happening?
    Genius:
  • 3,422 Answers
HI,
The internal circuitry of the amplifier is at fault.I believe you will have to get it repaired to fix it up.
Goodluck,
Please don't forget to rate the solution
Posted on May 01, 2008
    Genius:
  • 1,447 Answers
Make sure wirings are not pinched and try replacing the fuse as well.
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 01, 2008
    check the crossover setting as well if you have one
    Here is the link for the manual
    ALPINE
    same with unit
Diagram for mrv-f3502 500w car audio power amplifier v12
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Jul 27, 2012 | Car Audio & Video
Lost instruction manual mrv-100m v12 car amp
Hello hlanderson,
You can download a copy from Alpine's support vault here.
Hope this helps.
Aug 13, 2009 | Alpine Car Audio & Video
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
Amp will not power on at all
did you use the exact parts? did you also replace the pwm controller
Sep 12, 2008 | Alpine MRV-F345 Car Audio Amplifier
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
Alpine MRV-F345 VLT ERROR
This is an indication of a voltage error, I have seen this when the voltage regulator or the car battery is begining to have a problem supplying enough current to the amplifier. Check the voltage levels with the amp turned off and then turn on the amplifier, if the voltage drops this means that there is poor voltage regulation and this may mean that you will have to replace the car's voltage regulator.
I hope this helps,
Thank you,
Shuttle83
Apr 20, 2008 | Car Audio & Video
Alpine V12 MRV-T707
power wire from fuse block goes to "the 1 that says power"...remote is used to have your device turn another device on...like a cd changer
May 28, 2007 | Alpine MRV-T707 Car Audio Amplifier
this isnt a complex problem but both units may need service
Mar 12, 2007 | Alpine MRV-F345 Car Audio Amplifier
Alpine MRV-F345 Car Audio Amplifier Logo
171 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
