Hi my washing machine smells i have used products to wash out pipes. we have taken out all the pipes and washed them but it still smells. can you help.
  • 487 Answers
Try first running a hot load with one towel with vinegar.
Normally that works
After that repeat with one cup of bleach
That should take care of it
Posted on May 01, 2008
My wash water smells bad. I leave the lid open between loads. When I do a wash it smells really bad.
After extended use, your washing machine can develop odors from the water, soap, residue, etc. The easiest and first thing to try is washing machine cleaner. You add this to the washer and then run a wash cycle. The product comes with instructions. Depending on the condition of your washer, you may have to run the cleaner through more than once.
You can usually purchase a washing machine cleaning product form stores that carry laundry detergent.
Here is a link to a product that you can try::
http://tide.com/en-us/shop/special-needs/additives/tide-washing-machine-cleaner
Here is a link for cleaning of a washing machine:
http://www.goodhousekeeping.com/institute/a23727/how-to-clean-a-washing-machine/
Aug 29, 2015 | Speed Queen 3.3 Cu.Ft. Heavy Duty Top Load...
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Our washing machine smells at the start of a wash cycle and smells of fish.We have done ample clean cycles using different products and washed using various washing powders and liquids etc at 90+c. is...
posibly not melting glue as there not used in making the machine try putting a blech hot water wash cycle a few times in the machine and if the washer is not being used leve the door open to allow the unit to breath and stop using powder wash detergent use liquid wash detergent
best luck
Nov 10, 2010 | Bosch Washing Machines
Foul odor after washing - what's happening? should the drain hose go down to the floor, before it goes back up to the house drain?
This is hard to rectify without seeing the machine, but it sounds like you are getting drain smells. Do you have a water trap in your pipe that goes to the drain? if not then install one this will stop the drain smell getting into the house. No the outlet pipe from the washing machine should not need to go to the floor. Other than that you may have a build up of slime in your machine you can by products in the shop for cleaning the machine.
Aug 05, 2009 | Kenmore Washing Machines
Washing comes out smelling horrible! Any ideas?
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
Please rate my solution.
Thanks.
May 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
Moldy smell
Hi Jewel,
You may want to try some Washer Magic, or similar product specifically designed to clean out washing machines. I personally use Affresh in my front loader and it works very well.
SG
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Stale water smell
If the washing machine itself smells bad when you open the door, it could be that it's covered in a horrible grease and gunge inside all the hoses and the tub. This particularly affects older washing machines and is common with washing machines that have only really been used at 40° or where only liquid detergent has been used.
Not using enough soap detergent over a long period of time can cause a build up of grease and therefore bad smells.
Get rid of washing machine smells
You could try to clean the washing machine inside using Soda crystals which dissolve grease. I recommend putting half a packet inside the drum and washing on a boil wash (or follow instructions on the packet) Using this method every month or so, or using ordinary detergent if no soda crystals are available can help prevent smells from your washing machine. If your washing machine is badly affected by grease and slime, it may be very difficult to remove it.
Get rid of washing machine odours using vinegar
White distilled vinegar has an array of uses. For bad washing machine smells, try putting half a cup of white vinegar inside an empty machine and put it on a boil wash. Because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 30 seconds and then pour the vinegar into the soap drawer to let it wash down into the machine. I've had reports back from people that this does actually work.
Mar 07, 2008 | Hotpoint WMA40 Front Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
