Question about Lexmark Office Equipment & Supplies
Lexmark c510 error code 83 PHOTODEV CART MISSING even though the cart is new. the printer won't go past this message. I have cleaned the contacts. Is there a way to force a reset or force the system to go past the error?
SOURCE: 83 PHOTODEV CART MISSING
To specify which supply has been replaced:
  1. Make sure the printer is on and the Ready message is displayed.
  2. Press and release Menu until you see Supplies Menu, and then press Select.
  3. Press and release Menu until you see Replace Supplies, and then press Select.
  4. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  5. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  6. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  7. Press and release Return until the printer returns to the Ready state.
Posted on Feb 27, 2008
  • 4 Answers
SOURCE: error message 83 - photodev cart exhausted
The photoev cart is the photo developer cartridge.
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Posted on Dec 08, 2008
  • 4 Answers
SOURCE: lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Posted on Dec 09, 2008
FixinFax
  • 3085 Answers
SOURCE: Error message
You need to replace the toner cartridge
Posted on Oct 30, 2009
Printtech
  • 1087 Answers
SOURCE: message of '83 photodev cart exhausted', where
Here's an article in the Lexmark website on How to Replace the Photodeveloper Cartridge in the C510. Just click on this link: http://bit.ly/bOJQDz. Follow the instructions carefully. Hope this helps.
Posted on Jun 14, 2010
My Lexmark C510 Laser Printer was giving me- 83 Photodev Cart Warning so I replaced Photodeloper but printer is not recognizing that I replaced it
  1. Press and release Menu until you see Supplies Menu, and then press Select.
  2. Press and release Menu until you see Replace Supplies, and then press Select.
  3. Press and release Menu until you see the relevant item:
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
  4. Make sure the item you replaced is on the second line of the operator panel. Press Select.
  5. Press and release Menu until you see Replaced, and then press Select. The Saved message appears.
  6. Press and release Return until the printer returns to the Ready state.
Feb 14, 2012 | Lexmark C510 Laser Printer
Hi, I have a Lexmark C510 Laser Printerphotodev exhausted message, changed it and still have the massage! Maybe it needs to be reset? I shut it off and restarted, but still have the message.. HELP!...
The 83 Photodev Cart Exhausted message on the operator panel indicates that you must replace the photodeveloper cartridge immediately. To replace your photodeveloper cartridge please clink on the link below.
http://bitly.com/nG3Toi
Jun 17, 2011 | Lexmark C510 Laser Printer
屏å¹?提示ï¼?83 photodev Cart Exhausted æ??ä¹?å??äº?ï¼?
You need the OPC Image Unit 20K0504 which contains the developer. This is a supply item
Whit
Item, Inc.
Aug 10, 2010 | Lexmark C510 Laser Printer
Message of '83 photodev cart exhausted', where abouts is it, in the machine?
Jun 14, 2010 | Lexmark C510 Laser Printer
Not printing
The problem could be the Developer Clutches not turning the cartridge. Thus toner does not develop and get transferred to the photodev cart. This may be due to a missing retainer clip try replacing the clutches. That should solve the problem.
Dec 09, 2009 | Lexmark C510 Laser Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error message 83 - photodev cart exhausted
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Dec 08, 2008 | Lexmark C510 Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
pages 184 and 185
"Message:
What you can do:
Continuing below
Message:
What you can do:
Continuing below
Message:
installed.
What you can do:
Nov 26, 2008 | Lexmark C510 Laser Printer
      • Yellow Toner
      • Magenta Toner
      • Cyan Toner
      • Black Toner
      • Photodev Cart
      • Fuser
Oct 15, 2007 | Lexmark C510 Laser Printer
439 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
