Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Cleaning Solution
Do I pour the vinegar in the detergent dispenser or just in with the towel?
  • 487 Answers
Just in the soap dispenser as soon as it starts filling.
Posted on May 01, 2008
  • eric bosman
    eric bosman May 01, 2008
    make sure you use the hot cycle.
When washing towels black mould marks are seen on the towels. Towels are also getting holes.
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
If your washing is getting holed, it could be because of incorrect use of chlorine bleach being poured directly onto clothing, unfastened buckles and zippers in the wash, ribs and tears and broken threads in the materials and overloading the washer. Degradation of the fabrics could also be a contributing factor.
Apr 27, 2011 | Whirlpool Washing Machines
My Calypso washer beats up my clothes but doesn't clean them well. I have holes in my linens and all my towels have pulls in the terry.
I don't have the solution but I have the problem. I bought all new towels 2 years ago and they are all ruined.
Jan 03, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Extra part
GVW9959K
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GVW9959K
click on your model number. In the new window click on the diagrams in the left-hand side. You will have to examine them to try and find the rubber part.
Mar 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Too much water on clothers
this is common with this model
may need a new lid
Oct 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Stinky Washer
we had that problem too...  we ran a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
151 people viewed this question
Dan Webster
Dan Webster
Sal De
