Display on Xerox Phaser 6350 not working unable to network printer
  • HandyFred Sep 02, 2008
    We have been replacing ours every 6 months or so. The last one was suppose to be the redesigned display. Xerox now suggest replacing the power supply.
  • Anonymous Jan 20, 2009
    there is only "xerox " on the diplay ...
    President:
  • 2,072 Answers
Defective Control Panel. In early 2006 a defect was found with some of the Phaser Control Panels. This has been corrected in manufacturing and new versions of the control panel placed into inventory. Solution: Display on Xerox Phaser 6350 - thumbsup.gif Fixed! thumbsdn.gif Did not fix. Try the Engine Only test print on the rear of the machine. If the print is successful, the display is defective and needs to be replaced. Using the Centerware IS (CWIS) and using the Support Tab will connect you to Knowledgebase for any procedures on how to change this control panel. Contact Product Support, 800-835-6100 for any other questions regarding this issue.
Posted on May 01, 2008
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If your Xerox Phaser 6300, 6350 or 6360 has a blank display, garbled characters, inverted or upside down display you most likely need to replace the control panel. it is very easy to do and takes about a minute. Here's a video to show you how
Posted on Feb 03, 2011
There is no display on the screen.
if your display on your Xerox phaser 6350 is blank you should replace the control panel (part# 333-4424-00). It's a pretty easy fix, takes about 5 to 10 minutes to install. Here is a video that shows you how. Iteminc.com has this part in stock and ships same day. Hope this helps, and thanks for using FixYa!
Feb 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
Xerox phaser 6350 has stopped printing on two sides. Have document which did print correctly two weeks ago, now does not.
you need to change the settings again on the printer driver itself:) when printing choose the printer and the settings under printer properties
Nov 20, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox phaser 6350dp magenta flooding
Your Magenta developers are probably failing. Order 116-2009-00 and see if that fixes it.
Whit
Item, Inc.
Jun 15, 2009 | Xerox Phaser 6350/YDP Laser Printer
Phaser 6350 flooded with magenta toner
Problem developers start leaking toner. The problem is that some times the toner spuills into developers below it and damaging them. The problem may appear as a grinding noise that may indicate a developer gear/motor problem, when in fact its a bad developer that is not running smoothly. It may be expensive, and you may have to replace ALL the Developers.
Jun 15, 2009 | Xerox Phaser 6350/YDT Laser Printer
The menu screen is blank
If your 6350 has a blank display the most common reason is a bad control panel. It takes about a minute to replace and is very easy. Hope this video helps! Enjoy ">
Sep 18, 2008 | Xerox Phaser 6350/YDT Laser Printer
1,306 people viewed this question
jasbo
jasbo
