Question about Morphy Richards 43072 Cordless Electric Kettle
Morphy richards opera
Light remains on,but kettle does not boil
  • KEITH SMITH Sep 04, 2008
    morphy richards opera kettle does not whistle
  • Anonymous Nov 08, 2008
    Yes I have morphy richard cordless which stopped working for no reason and I did not keep the receipt.
  • 5,568 Answers
Either the heating element has failed (open) or the thermal fuse has failed.
The latter is a protective device that melts at a specified temperature and acts as any other fuse does, it interrupts the flow of power.
The indicator is probably a small neon lamp (or an LED) that is across the line (or battery in your case) and does not extinguish when the thermal fuse is blown.
The fuse is not likely replaceable by the user since it is often welded into the circuit and not available at a consumer electronics outlet.
Posted on May 01, 2008
Do you have a base for Morphy Richards jug kettle. no. 43161
we do not as we are not the manufacturer or a rep of said company .
Jul 04, 2016 | Morphy Richards Kitchen Appliances -...
How do i clean the inside of illuma kettle
You can use Lime-Away (at Home Depot) or Apple Cider vinegar. It seems to work much better then regular vinegar. In either case let it boil if it has no element inside the water compartment, put a small clean rag inside and use a wooden spoon to clean the heavier areas. Boil it a few times, then dump it, and boil and clean with clean water twice, then put it back in service.
Feb 26, 2015 | Morphy Richards Illuma 43121 Cordless...
Morphy Richards 43960 kettle won't boil,even thou the light is on. This kettle is only 14 mths old
There is a therm o guard in there looks like a bullet. anything that has a heating element has one. mouser electronics sells them.
Oct 20, 2014 | Morphy Richards 43072 Cordless Electric...
Morphy richards 43960 kettle not boiling
I think it has died a natural death, kitty. Get a new one it will be cheaper than fixing this one.
Feb 11, 2014 | Morphy Richards Kitchen Appliances -...
Does not boil water
Our kettle light comes on but not boiling water
Jan 08, 2014 | Morphy Richards 43072 Cordless Electric...
The kettle switches off before it is boiled
Yes you got it . Try cleaning the pin if not its done .
Jan 07, 2018 | Morphy Richards Kitchen Appliances -...
Kettle not boiling water
Please use a multimeter and check the continuity of the power cord , now switch on and test the coils resisitance. If there is no continuity then the coil is open and the element has to be changed.
You need to contact spares dept of murphy richards.
please check the link below for spares;
Sep 20, 2011 | Morphy Richards 43072 Cordless Electric...
Hi there Hiw can I turn off the whistle on the Morphy Richards Accent kettle please?
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
Mar 03, 2011 | Morphy Richards 43691 Cordless Electric...
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
Morphy Richards 43072 Cordless Electric Kettle Logo
981 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Oloyede Monsuru
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
