Question about Norelco Cool Skin 7775X Electric Shaver
The left red light button is on constantly and is using up the battery ever few days. Manual says to change blades which I did. How do I turn off light? I submitted this request some2 weeks ago and have no reply
  • ellisinc May 06, 2008
    The shaver is about 15 months old. Does battery need to be replaced? Usage is about 320 times a year and blades are washed under hot water after every use.
    Genius:
  • 1,019 Answers
Theres A cleaning indicator. And A Low Battery Indicator on this Model.
Make sure you have no hairs inside the shaver unit, or lodged between the blades. This will cause the cleaning indicator to light up.
Secondly, depending on the age of the Battery and shaver.
You may need to replace the rechargable Battery Unit. With A New One.
Hope this helps solve your Problem.
Mike.
Posted on May 01, 2008
  • Mike Waldron May 07, 2008
    I would definately suggest A new replacement rechargable Battery.
    if it,s 15 months old. It will have been charged/Discharged hundreds of times. A replacement Battery should cure your light Problem On The Shaver. If it,s not blocked hairs triggering the light. it,ll be the battery not receiving a full charge.
    Please don,t forget to Rate the Solution, once you,ve resolved The problem.
    many thanks mike.
  • 3,037 Answers
I would try removing the battery. or leaving it on to discharge and see if that works. The battery may need to be cut out and resoldered back in.
Let me know if this doesn't work and we can explore further options
thanks
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    How often do you charge it?
    Genius:
  • 1,447 Answers
Make sure that blades are installed correctly, take it out and reinstall it. remove battery while installing and try charging it again, if issue persist chances are you need to have it service, if within warranty contact manufacturer.
Best i got..
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 07, 2008
    Yep chances are you need to change the batteries
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Bell radian bke light change batteries
The 'top' button that turns the light on.
You must press and hold the bottom button to release the light/battery container. It is still very difficult to force out of the casing. I used a screw drive (flat blade) to force the little tabs on the outside of the LIGHT edges to separate the two.
Sep 20, 2012 | Bell Radian Bike Light Set Black Red
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Hello. I have a Mustek PowerMust USB 800 device. Few times a day (2-3 times) it shuts down my computer. It appears the red light instantly and it starts to make a sound. Even after i press the button and...
Did you read the manual for your UPS ?
I read it - there was something about lamp ledding - different ledding of lamps and different frequncy of noisy sound can mean different problems - try read manual.
I think, your description means that you need to change battery.
Battery work 2years +- .
Jul 05, 2011 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
The red light stays on permanetly despite changing batteries on t.v remote control
I had this same problem as well. It was after I upgraded the OS I had the issue with my LED red light on constantly. I figured out it was the colorpearl application because it is not compatible with the new 4.5 OS.
Apr 20, 2008 | RIM BlackBerry Pearl 8100
Red Light!
Hi xx
It sure does sound like a battery. If it is more than 12 months old, and regularly charged(daily) , then it will need replacement.
regards
Graeme
Mar 11, 2008 | HP iPAQ hw6965 Smartphone
New battery will not recharge
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Dec 19, 2006 | QVS NetStar (UPS650A) UPS System
Norelco Cool Skin 7775X Electric Shaver Logo
69 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
