Question about Jenn-Air Microwave Ovens
Jenn Air WM2780B (Wall oven with Microwave) - it starting beeping, got a code that said F1, wouldn't stop beeping even after pushing cancel and stop buttons pushed. So we had to shut off circuit breaker for awhile & the put it on. Do you know what's going on? Thank You for your help
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Jenn-air model jmc7000
First of all, a microwave should be on its own circuit breaker. It's very common for a breaker to blow if it has a microwave and a fridge, etc., on the same circuit. The fuse is usually rated at a lower current than the breaker, so it's very unusual for a microwave to blow a breaker without blowing the fuse. Once a breaker blows a few times, it should really be replaced. It has a bimetallic element which will experience metal fatigue and become inaccurate. This could be the problem, too. The breaker for a microwave should be no less than 15 amps, and 20-30 is better. If you or a friend has a a clamp-on ammeter, you can monitor the current the microwave consumes. This can be helpful in diagnosis.
Posted on Nov 01, 2006
SOURCE: JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
I have Model #JER8750AAB Serial#16776012WK When uising the self cleaning feature, oven stopped and F1 displayed on stove ??
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Dec 19, 2010 | Jenn-Air Microwave Ovens
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Setting clock on Jenn Air M166 built in microwave
sure..push clock pad twice..set time..push stop/start
Mar 09, 2008 | Microwave Ovens
JMV8208AAS Jenn-Air runs all by itself
check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
