My coleman Evcon model DGATO70BDC 1994 starts up and then locks out. The pilot lights and then furnace runs for maybe 2-5 minutes and all that is still running is the air chamber fan. I am thinking of just replacing all parts that could be responsible the problem. There's not much there as probably you know. There is no circuit board just basic electronic ignition,relays thermo senors and etc.. Any help would greatly be appreciated. James
  • 828 Answers
Does your furnace have an air flow sensor? Blowing out the lowest tube will sometimes clear it and allow your furnace to operate. Lack of differential pressure across the burner will cause a lockout.
Posted on May 01, 2008
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
Posted on May 09, 2008
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
Sounds like it isn't getting a call for heat. If you have a digital thermostat it could be the problem. I have seen them look like they are working but burn out. A simple way to check is take the stat off the wall. There is 2 wires. It's low voltage so don't worry about shock. Touch and hold them together. If it fires up change the t stat. On a . 2 wire it makes no difference which goes to W or R
Oct 16, 2013 | Heating & Cooling
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
My furnace is a Coleman Evcon DGAT090BDD and it won't turn on at all. The green light is solid green, I can't find the pilot light, and its freezing in here. Please help me!!
Your furnace has an electronic ignitor so there is no pilot to lite...... I would shut power off to the furnace and then restart it....this will reset the control board and take it out of lock out..... If the hot surface doesn't glow after you restart it then it is probable burned out and will have to be replaced.....It is inside the furnace right behind the Gas Valve. Will have two wires running to it from the control board....If you can't get it goingby shuting off the power and reseting it then you many want to call your Service Company to have them check it out.....
May 05, 2011 | Heating & Cooling
How to replace ignitor on coleman furnac evcon model dgato70bdc i have a new ign and i need to know how much of the front of the furnace i need to remove or what part of the front to remove, the gas valve...
Hi some of these you do not have to remove the burner you just indo the hot surface ignitor its black with ceramic base ? if so you remove the metal cover over the burner and swap it out .
Feb 04, 2010 | Heating & Cooling
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
302 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
