Nintendo Wii Console Logo
Posted on May 01, 2008
Cant get pased language select screen
I get to the language select screen and the controler wont go ahed to next screen it wont werk
  • 3 more comments
  • tm0511 Dec 20, 2008
    we just bought a wii and it wont pass the language screen. we select the button but it doesnt work. what next
  • lmead2123 Dec 21, 2008
    we get to laungue select screen then nothing will happen weve done everything move back resync reset sensor bars everything
  • Anonymous Dec 26, 2008
    I CANT GET PAST THE LANGUAGE SCREEN
  • ben1994 Jan 18, 2009
    i cant get past the language select screen
  • Michael Treiber
    Michael Treiber May 11, 2010
    does it do that every time?
1eyedmonky
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on May 03, 2008
1eyedmonky
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
550
Points
8
If you can work the controler try moving back a bit it wont work really close up if it still doesnt work take the controller back it could be damaged
On the riitek mwk 12 how do you use the key board to type umlat letters ihave only one hand to use due to a stroke, I cant use both hands together regards Posted by Edgar Barnes on May 28, 20
The keyboard itself will not determine which characters are typed on the screen - this is handled by the operating system.
If you're using Windows 10, you'll want to add a keyboard layout by going into the Settings menu (found by clicking the Windows icon at the bottom left of your desktop - then clicking the gear cog).
Then click on Time & Language
Then click on Language
Then you can select the plus sign to add a preferred language, and then select "Options" to add a layout from that language.
On the next screen, click the "Add a keyboard" button and select the keyboard you'd like to add.
www.6ya.com/brandonu
1helpful
How do i change lanuages on my itouch air
  1. Open Settings. On the Home screen, tap Settings.
  2. Tap General. On the next screen, tap General.
  3. Select Language & Region. Scroll down and tap Language & Region.
  4. Tap Device language. On the next screen, tap "[Device] Language".
  5. Select your language. Pick your language from the list. ...
  6. Confirm your selection.
Why my tablet wont let me select the next button....its frozen
The only thing I can suggest is to disconnect everything and remove the battery for a few minutes. Then, reinstall the battery, connect your cables and reboot, in the hope that everything will reset itself.
I hhave a toshiba sat and it wont get out of the boot screen. Windows wont load. I dont have a windows cd
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
1helpful
I wont change my phone to english but i cant read it ita in a nother language
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
My netbook wont go to the home screen just shows a bluee screen and the padlock with (a) keeps flashing
  1. Restart your computer.
  2. Look for the prompt "Press any key to boot from CD/DVD" and press "Enter."
  3. Select your language preferences and click "Next."
  4. Select "Repair your computer." Click "Next." This launches the "System Recovery Options" screen.
  5. Choose the "System Restore" option from the menu. This will open the "System Restore" page. Click "Next."
  6. Select "Choose a different restore point" and click "Next."
  7. Select a restore point from the list and click "Next." Choose a restoration point prior to your blue screen error.
  8. Click "Finish." System Restore is restoring your computer to a point prior to the time that the blue screen error occurred.
3helpful
Just started up phone cant get it to go onto english language
Once you on the home screen, if you click the left side button with the four square boxes above (the three sliver ones), select settings which has a hammer and spanner (i dont know what language you in so ill say like any symbols that help). On the next screen is a menu, if you go down to bottom to fourth from the bottom called locale & text, click that and the first box saying select locale and then english.. that should change the language to english
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
I cannot read japan writings i wanr it to convert in english
To change the Language, take these steps: Click the “Start” button, click Control Panel, in the (right) “Pane.” Scroll to find: Clock, Language, and Region, click to open.In the next (window), click on Regional and Language Options. Next, click “Formats”, under the “Current format:” click on the (down) arrow; select the “preferred” language. Next click Apply”, click “OK.”
2answers
Ipod 4th gen nano is frozen on the language selection screen.
That could be one of two problems: Either the cord of the click wheel has been disconnected from its socket which will be an easy fix and you only have to pay labor, or you may just need a new click wheel which should still be cheap.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
