Question about Epson Stylus Photo R300 InkJet Printer
Print layout for CD
I can print a 4 photo layout directly from the printer, but want to do some fancy stuff on the computer first; I can't make it give me anything but a single photo layout. Help, please! Nancy
    Genius:
  • 2,985 Answers
You need a photo editor. plent out there simply do a google.
Posted on Jun 14, 2008
Using Easy print
If you are using Easy Photo Print ( highly recommended) select your images, then select your paper type and size, then select your layout and print.
If you are printing direct or wirelessly, your options are more limited to A4 or 6x4".
Mar 02, 2015 | Canon MG5350 Wireless PIXMA Inkjet...
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
Aug 03, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
UNABLE TO PRINT LANDSCAPE
To print photos in landscape orientation use Irfanview. Install this software and use it to view photos. Very easy settings are available in print options from its options menu.
To print documents in landscape, choose landscape orientation from page layout.
For all other applications, set the orientation from the printer's properties inside the control panel in Windows.
Note: You cannot adjust it to print in landscape for direct copying from the printer's panel.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
I have an HP PHOTOSMART 8250 printer. When I print a photo in the photo tray it only prints part of the photo. How do I remedy this?
Hello, This sounds like a layout problem.
Here's what to do: After you've chosen the photo you'd like to print, make sure you press Layout on the printer control panel to select a layout for that photo. Press the button repeatedly to move through the six layout options. When a memory card is inserted, the selected layout is displayed in the bottom center of the printer screen. All photos selected from the printer control panel will print in the selected layout.
For more information, here's an easily clickable link to the manual for this printer. This link is part of the HP official web site.
http://h10032.www1.hp.com/ctg/Manual/c00378138.pdf
I hope this helps you!
- CBR2009
Aug 09, 2009 | HP Photosmart 8250 InkJet Printer
Dell 1700 prints test page on enlarged print over 4 pages
It sounds as if it's set to print in poster format,
1 From the computer’s software application, select File then Print.
2 Click Properties (or Options, Printer, or Setup, depending on the application) to view the
printer driver settings.
3 From the Page Layout tab, click More Page Layout Options.
Aug 30, 2008 | Dell 1700n Laser Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Horizontal lines
do a nozzle check, or printer utility check on the printer and see if this helps.
Jun 08, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Epson Stylus Photo R300 InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
