Un-installing - Computers & Internet
    Champion:
  • 268 Answers
Start menu
go to the control panel, select add or remove programs, soon enough you will come across a list of programs, select the program you want to uninstall
Posted on May 01, 2008
  • 13,433 Answers
To uninstall programs
press start -> then control panel -> then add or remove programs.
select the program you want to uninstall and click uninstall
I want to make my acer aspire one to run faster, but i dont know what programs i dont need to uninstall it, can someone help?
Normal un-installation will not help you to speed up your acer one netbook, because un-installation will not remove keys from registry, instead of un-installation you do three things
  1. Start>Run > type %temp% >enter, then select all and delete
  2. Start>Run > type temp >enter also delete all temporary file
  3. Start>Run>type prefetch> enter, then delete all
  4. Run> msconfig>enter then select "startup" click on Disable all
enable only urgent start-up applications (eg:bluetoot,touchpad)
you can speed up by these ways, other ways format with fresh OS do the same after installation of all softwares, avoid installation of un-necessary softwares... Thank you
Aug 27, 2011 | Computers & Internet
How can I uninstall the National Geographic Design Program? The disc has no uninstall software and the icon does not appear in my computer's uninstall application! Thanks so much for your...
Assuming you have Windows Vista, follow below.
The program should be listed in the programs page.
Press "Start" button in lower left corner of your screen....then select "Control Panel".....then select "Un-install Programs".
You should see a list of programs....select the program name you want to un-install then select "un-install"
The program should be un-installed in a few minutes.
Jul 25, 2011 | Computers & Internet
My farmville game almost 98% but never complete.
Hi.
Based on the information you have provided, it seems that the issue is due to the Adobe Flash Player.
All the Games on Facebook require Adobe Flash player.
Hence, it would be better to install the latest version of the Adobe Flash Player.
Before installing the latest version, it is required to un-install the version which is already installed in the Computer.
Then, install the latest version of the Adobe Flash Player.
You may un-install the older version of the Adobe Flash Player by using the "Add or Remove Programs" feature.
Once you have un-installed the older version of the Flash player, then you may install the latest version.
Link to download the latest version of the Adobe Flash Player.
http://download.macromedia.com/pub/flashplayer/updaters/10/flashplayer_10_ax_debug.exe
Please click on the above link to download the Adobe Flash Player.
Please un-install the older version of the Flash player and then install the latest one.
Performing the above mentioned steps should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Computers & Internet
How do i resolve the issue
The program you are trying to install is ether 64 BIT or not compatable
Jan 14, 2010 | Computers & Internet
Hi, I want to install a Digital thermostat with 24 Voltage, what I need to install into a MasterCool
Ya te dije que necesitas un reelevador de 24 VAC de dos contactos normalmente abiertos y un transformador de AC de 120 a 12 volts. Jejeje E. Verdugo.
P.D.Aqui en Chihuahua venden el reelevador a 270 pesos y el transformador dondequiera lo hayas nomas fijate que sea de minimo un amper de corriente.
Jul 31, 2009 | Heating & Cooling
UN-Install Nero Burning rom 5.5 FREE Version (now out of date)
If you are running XP or Vista, I would run a system restore. Go into start all programs, accessories, system tools, system restore and choose a date prior to the day you installed nero.
Armymason
Mar 02, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
INSTALLER LECTEUR CD-ROM
Lorsque j'ai un problème comme le vôtre, je trouve toujours plusieurs sites qui expliquent pas à pas comment installer des lecteurs cd et dvd dans un ordinateur de bureau.
J'ai fait une recherche rapide sur Google avec les mots clés 'comment réinstaller lecteur cd et dvd' et j'ai trouvé rapidement plusieurs sites tel celui-ci:
http://www.cnetfrance.fr/produits/installer-un-graveur-de-dvd-ou-de-cd-39157407.htm
Jan 08, 2009 | Computers & Internet
Iwould support for pc cam technical support
salut
j ai un cam ebox fc model p 710 dont j ai perdu le cd installation veuillez m aider a l installer ou bien de m envoyer un manuel d installation
merci
Sep 22, 2008 | Cameras
CANT INSTALL MY PHILIPS PC CAMERA
It's a common mistake to connect almost any USB device before the software/driver.. If you have done this, you need to disconnect the usb cable, un-install the software, boot the pc, then re-install the software. There might be a spot in the installation process where it asks you to connect the webcam.. Do it then, not before. If it does not ask you to plug the cable in, do it after you have booted the pc. The un-install software is usually bundled with the install, on the same CD.. If not, you might have to download it from the vendors website, or use the windows un-installer. Rgds, dave
May 02, 2008 | Philips J44414
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
