Question about Vacuums
Its hard to explain, I have a 4704 p Boss LightWeight Upright. The piece that holds the bagless cup onto the vacuum broke. So now the cup falls off, is there a way to get another piece or would i have to by a new vacuum for this one little piece being broken
    President:
  • 1,673 Answers
Should be able to order what you need. Find a local shop, along with your model number, they should be able to order it for you.
Posted on May 01, 2008
Eureka Boss Capture 8803AVZ Bagless Upright Vacuum smells like it is burning
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
Apr 30, 2011 | Eureka Boss Capture 8803AVZ Bagless...
I have the eureka boss 4495 widetrack and the end piece of the beater bar broke off. I guess I put it back together wrong when I put a new belt on. Where can I get a replacement part and will it work do...
Call the Eureka people (1-800-282-2886) and describe to them what the beater bar thingy that you broke is. Ask them if you can order that unit--if you think you can install it. Otherwise, ask them where to the authorized repair person closest to you is located. Price the repair versus a new vacuum and good luck.
Apr 20, 2011 | Eureka 4495A Bagless Upright Vacuum
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
What is the cause of the loud noise in my vaccum it's a eureka boss bagless
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
Nov 18, 2010 | Eureka 5856BVZ Boss Bagless Upright...
How to remove the eureka the boss super lite filter
Push up on the black slide button just above the dump cup and hold. With your other hand remove the dump cup. Once you have the dump cup removed, pull up on the rubber section of the filter to remove and clean the filter.
Feb 13, 2010 | Eureka Boss Superbroom Bagless VacuumStick...
Hello! Hoover WindTunnel broken! aRGGHHH
I would definitely check out the epoxy route.
Jun 14, 2017 | Hoover U6630-900 WindTunnel Bagless...
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
