I have a Maytag stacked washer/dryer from hell - model MLE2000AYD, S/N23517203YD. Already replaced the circuit boards for $400.00 , now the thing won't spin. Fills with water and agitates fine. Indicator light says door is locked. Short of a hand grenade, what do you suggest?
  • 58 Answers
Most likely a timer, could be motor, but im leaning more towards timer
id recommend replacement the serial number places it as a 2000 i believe
Posted on May 01, 2008
I have a Neptune stacked washer and dryer front load and when the cycle completes there is a pool of water and the clothes are soaked. After listening to it, seems its not initiating the spin cycle. What...
Have you paid any attention if the dood lock light is coming on? If not check the Machine control board on the under the top of the dryer. There is a circuit board on the right front. On the board there is a resistor identified as R11. if it is burnt then the board and wax motor on the door latch assembly need replaced. If the lock light is coming on then you could have a bad Motor / Motor Control Board problem.
Jul 13, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag dryer model lde710
Check for a stuck relay. that's the only thing else that comes to mind
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
