Question about SanDisk Sansa E280 MP3 Player
Screen Readout My screen readout says nothing it is just a couple of what look like ink blots on a white background, a large one and a smaller one....... Just happened out of the blue, someone told me the readout is completely useless now.......true? It sill functions but I cant tell what is going on because the display just stays on those ink blots........
  • the best mom May 18, 2008
    Hello. I just bought my sansa 200 at a sale and the screen is just two ink blots one large one on the left and a small one on the right. It is perfectly chargd but wonèt let her do anything, she dowloaded musioc and everything on this thing and can not use it....wht is the problemé How much is a new screen and where can I get one? If anyone can help that would be great.....PLEASE HELP. She really wants to use her new snasa badly and I would love anyones input on how to fix this thing....
    thnks from single mom trying her best with daughter.
  • 52 Answers
Yes screen readout is bad... u need a new screen
Posted on May 14, 2008
How can I stop the Samsung gusto 3 from reading numbers of incoming calls.
I believe one of the Accessibility Readout options is enabled. From the home screen, press the Left soft key. Select Menu, then Settings. Go to Accessibility and then Easy-Setup. Check that the following are off: Full Readout, Digit Dial Readout, Alert Readout. (Alternatively, you can look at each of these individually from the Accessibility menu.) There may be other options to check in the Readout options but these seem the most likely.
I hope this helps.
Dec 21, 2017 | Samsung Cell Phones
Readout turned totally white After being in a Lot of rain. Cannot see digital readout at all.
Take a hair dryer to read out. Water will evaporate and eventually you will be able to see readout again. You may have to open up bezel to allow water vapor out or it will recondense on inside of bezel. Hope this helps.
Dec 31, 2010 | 2002 BMW K 1200 LT
I have Canon MP520, the screen has backlighting but no info, what is the fix please
Turn off printer.
Close readout cover.
Unplug printer. Wait at least 5 minutes.
Plug back in printer
Open readout cover
Turn printer on
This will reset the printer
If this does not work, try turn off printer
Open and close the readout cover slowly couple of times
Turn printer back on
If still does not work, try a different outlet
the voltage could be low.
Dec 26, 2010 | Canon PIXMA MP520 InkJet Printer
Phaser 8550 Problem. Window has been blank for a while, but it still was working until a few days ago. With a blank window, I can't try to follow instructions to try to fix on my own. The other day it just...
You need to contact Xerox on this one. The LCD readout being blank and the machine not responding is indicative of an internal board failure. The red light being on all of the time is an indication of a fault. Without a front panel readout of the fault you will only continue to guess what the problem is.
Definately contact Xerox about your problem or get in contact with a Xerox certified technician in your area.
Aug 26, 2009 | Office Equipment & Supplies
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
Sansa View has a "ink blot" graphic and a white background when I turn it on.
if its an inkblot you broke your screen..... the same thing happened to mine and i'm still trying to find a place to repair the screen.... if i find anything i'll tell you
Oct 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
RNGOFF KX-T7630
press the button below the readout "rngoff", let go, then rotate the volume control dial. It should raise the volume. The readout will now say "ring"
Jan 11, 2008 | Panasonic KX-T7630 Corded Phone
Sony cybershot dscp73 view screen
Good Day, LCD display is defective, pls contact nearest service center, no longer user serviceable, still u can use it using optical viewfinder, but you can no longer change settings, cause infos are displayed on the LCD screen. Thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
SanDisk Sansa E280 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
