Question about HP LaserJet 5200tn Printer
Getting to print BLACK & WHITE direct from the comp screen which has colour
  1. when wanting to print direct from your computor screen (which has colour content) in BLACK & WHITE ONLY how do you do this.I have pressed preferences then im stuck as i cant find the BLACK AND WHITE box to tick help me please wayne
  • 975 Answers
When you get the window of the printer go to preferences , then on top of window click color , then where it says COLOR OPTIONS , unclick the PRINT IN GRAYSCALE (uncheck the box) then click OK . and try again . hope this helps
Posted on May 01, 2008
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
My Epson Stylus NX400 wont print because I'm out of colored ink. I just want to print in black and white and I cannot bypass the error screen.
This because the coloured ink is sometimes mixed to get black. You will also damage the print head on them. Replace coloured ink to fix.
Mar 05, 2010 | HP DeskJet 1120cse InkJet Printer
My samsung monochrome laser mfp printer has colour ink in it and it will not print anything in colour. My comp is windows 7. It will only print black and white and I want to print a coloured document....
The printer you have got is a monochrome printer i.e. it can only print in black. If you require colored outputs you would require to go in for colored printer.
Thank you,
Have a good day.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Set printer to greyscale as the default
hi..that you can set the colour of the print to black
and white both in the printer and the computer.
check it out..
thank u..
rate me..
Apr 08, 2009 | HP PSC 2210 All-In-One InkJet Printer
Black (no colour) printing setting Ebson Stylus CX4800
Ask to print,when printer screen comes up go to properties on the top right then advanced on the bottom right (it'll ask if you really want this --you do) then on the bottom left there is a box to mark for black and white only
Jul 31, 2008 | Epson Stylus C66 Photo InkJet Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Printing in black and white
the only way i got mine printing was to replace the colour ink! sorry
Mar 12, 2008 | Epson Stylus C46 InkJet Printer
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP LaserJet 5200tn Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
