Question about SanDisk Sansa e250 MP3 Player
MTP mode my mp3 player is mtp mode how do i get it off
  • 4 Answers
1. Go to Setting->USB mode in the player.
2. You can then choose either MTP or MSC mode.
Posted on May 03, 2008
My computer used to let me download files but now it says I can't
Go to settings and look for MSC mode it will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Apr 06, 2010 | SanDisk Sansa Clip MP3 Player
Tip
Solve your MP3 Player Connection Problem.
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them.
You know you have some files on your player and can not find them now, you may have to change modes so they are available.
Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form.
  • Turn the player on, if it is not already
  • Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc...
  • Navigate to "Settings" on the main menu of the player.
  • After navigating to "Settings", you should see an option that states "USB" or "USB MODE"
  • From here we can select MSC or MTP modes (could vary based on player model)
  • Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu
  • Connect the player to your computer and verify it is connecting in the desired mode.
It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall
W*ndows Media Player 10 or 11
Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
on Jan 01, 2010 | Audio Players & Recorders
My MP3 stopped working. It doesn't need to be
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa Clip MP3 Player
How do I listen to downloaded audio book? SanDisk Sansa mp3 model E250
If the book was purchased from the net and came with a license, you will have to set the player to MTP mode and sync the book through Media player or QuickTime. MTP stands forMedia Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management, (DRM) or protected content. MP3's downloaded form services like Rhapsody and Napster even Amazon will only function in this MTP mode. Now, Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them.
Jan 21, 2010 | Audio Players & Recorders
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
Sansa c250 - How can I change from MSC mode to MTP mode?
From the Sansa c250’s Main Menu, go to Settings/USB/Auto Detect
or MSC to change the mode. Auto Detect settings will default to MTP mode.
Jul 24, 2009 | SanDisk Sansa e260 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Wont change back to mtp
. On the mp3 player, switch between the Usb and Mtp mode (The M button) on the side of the player.
May 17, 2009 | GPX MW3837 MP3 Player
MW3837 MP3 PLAYER
push the mtp mode button
Dec 20, 2007 | GPX MW3837 MP3 Player
MTP device not found in XP with WMP 11
solve your problem from my post:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
May 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
