Tried, but can't get mobo out of case
I had removed every single screw and part, but just can't get the motherboard out of the case. The LCD, Keyboard, top case, heatsink, the lags around the back VGA connector and parrallel port are all out. I can lift the motherboard, from one side but its very stiff near the cardbus area and the back area. I can't find anymore screws to remove.
  • 2ssk May 01, 2008
    The laptop is a HP ze4315us, and I need to get to the DC jack. The manual on HP's website is not helping with this portion much.
    Scholar:
  • 90 Answers
You need to remove the two screws from the card bus ... I know this problem was posted in May, and would hope you have it figured out by now. But for the other people who are wondering ... there's two screws in the card bus cage (pcmcia slot) ... remove those, and the board should come out, considering all other obvious screws are out.
Posted on Nov 16, 2008
  • 123 Answers
Try to contact them online tech support..maybe they could help..
Posted on May 03, 2008
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
I need to replace the motherboard and I would like a break down on how to do so. thank you
Just start be removing all the cables
Take note of how they attach and the orientation
Some have small latches that need to be pressed to remove them
Once you have those removed then take out any extra cards that may be installed
these are held in by a single screw on the rear metal bracket
On some cards (graphic) theye may also be a small latch near the inner most part of the slot itself that the card fits in 9can be fiddly on occasion)
Once the cards are removed you should be able to see the screws that retain the board to the case.
remove those and wiggle the motherboard carefully. If it is still stuck check that you did not miss a screw.
Depending on the case you may also have to remove hard drives as sometimes on the smaller cases the may overhang the board
You should now be able to remove the MOBO
When you install then it is almost the same procedure but double check that the holes on the new one line up with the old mounting posts.
Remove any that dont or move them to a new location that matches a hole on your new board.
Mar 10, 2011 | Computers & Internet
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
HI, I have an Acer Aspire AM5641-B5540A. THE SYSTEM IS COMPLETELY DEAD. i HAVE RULED OUT A BAD POWER SUPPLY. WHAT DO YOU THINK COULD BE THE PROBLEM?
I understand now that you really checked out that power supply. Before we rule out a dead mobo, you should make sure the on off switch on the computer case is not broken.
Look on your mobo and find the power switch leads from your case power button to your mobo and remove them. Short out these two pins with a small screw driver and see if computer goes on.
http://www.pctechbytes.com/troubleshooting/detail.php?How-to-Bypass-A-Motherboard-Case-Switch-8
If that fails, and you checked your memory and CPU, then well, R.I.P. motherboard.
Hank
Oct 06, 2009 | Computers & Internet
Pavilion dv2125nr won't boot
it could be dead mobo, it's actually the most probable cause of your problem, but there is this thing i've encountered with HP several times already. i know it's a long shot, but i'd like you to try and boot the laptop up after you've removed the DVD-drive. if this works, it's the DVD-drive that's broken, if not, it'll be the mobo...
Jul 01, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Wont post and buzzing noise
Don't mean to butt in here but I'll bet the 4 pin_ATX 12v connector is not connected to the board. That 4 pin_ATX 12v connector give's the CPU it's power. Without is the system will not boot. Some boards will give off that weird sound you are hearing.
Feb 29, 2008 | Computers & Internet
Dell Deminsion 2400
Typacally with a dell they have a prepritary mobo plate that slids into the case but if the mobo is directly screwed to the case and you can take the mobo connector panel off the case then yes you can. If the mobo is on the plate then more than likely no unless ya get the same mobo from ebay or the like :-(
Sep 15, 2007 | Dell (E210882) Motherboard
Blank screen, no asus logo or bios
Hi Cheers I myself had a motherboard like this, it's a great worker! I also service and repair these boards and one of the most problem is when using single RAM, put it's into the correct slot! please check the manual for this one, when moving these boards you need to take out the processor heat sink, some time if you may leave it, the board may get a hair-line crack due to heat sink leverage on the board
Dec 27, 2006 | ASUS A8N-SLI Motherboard
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
