I need my denon 5000 to be repaired, play buton not workin, needs new belt for wun of them, jus wana know where i can take em to get repaird
Neeed to repair my denon 5000
Posted on Nov 26, 2008
  • 2,322 Answers
Click here to find the model you have and browse to locate the part(s) you need.
Posted on May 01, 2008
How do I repair a miss in my 91 geo storm?
Hi Keith:
Sounds like it could be time for a tune up.
Changing the spark plugs would probably be my first step.
Jul 17, 2015 | 1991 Geo Storm
Denon avr 95 analog/digital button not working
I just posted help finding a switch (if it was a bad tact switch that should help). If it is much larger than an eraser on a pencil you will need a different type of switch. I am assuming that you checked the switch with an ohm meter. If not there could be many other problems. If the display powers up for a few seconds then shuts down it likely has a bad output transistor and possibly other bad components which will require more than a few lines on "fixya". Good Luck!
Dec 13, 2013 | Denon Audio Players & Recorders
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Ge dryer stopped workin its less than 2 years old... reset breakers and everything i also vacumed the back of it out where the hose goes in and still now working. is there a reset buton or whatd does this...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 17, 2010 | GE Dryers
My turbo gto manual crunchs in ta 3rd evry time
if it only has problems going into 1 gear, it's most likely the synchro for that gear inside the transmission. but if this appeared out of thin air immediately after the hydraulic change, then i would definitely try re-bleeding the system first
Sep 29, 2009 | 1991 Mitsubishi 3000GT
Dvd won't play on my acer 5000
I received the same problem last night on my laptop.Its jus a display setting that u have to change for ur dvds to work.If that doesnt help u should probably jus try install a few codecs.
I would suggest u download and use VLC media player.Plays every possible file u need.
Hope this helps.
If my solution was of any use to u, please gimme a RATING on FIXYA.
Thank u.
Apr 09, 2009 | Acer Aspire 5000 Notebook
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Cybershot dsc w120 - turn power on and off (lens problem) it was dropped
I got an estimate to fix the camera for 129$ but thats **** i would rather buy a new camera. the funny thing is i dont need to. someone was joking and said well "how did u break it?" and i said "i dropped it" then they said " well drop it again" guess what? we lightly tapped the camera on the desk and as we were all laughing at how stupid it was to do that we turned it on and the damn thing was working!!!!!!
JUST 2 3 TAPS AND UR CAMERA WILL BE WORKIN I KNOW it sound stupid someone suggested me i thought it a joke but a tried it i gave 3 taps and it was nt workin but after 9 taps its was workin jus try it:)
Oct 12, 2008 | Cameras
Response to the solution posted
See my other post. its very easy to replace the mechanism. Theres a printboard that seems to be hard to remove, but beware, you only need to remove the screews that holds the brassboard, and all the cables. Then You have acces to the Mec, wich only needs four screews to remove and thats it. Should only need half an our or so.
Good luck. Niels Peter - Denmark
PS Actually You can disable the automatic standby. Read the manual, cant remember the procedure.
Dec 02, 2007 | Denon DVD-5000 DVD Player
48 people viewed this question
 Grubhead
Grubhead
