Question about Apple iPhone Smartphone
I have an iphone I downloaded the ants application which seems to have closed the phone down completely I cant get to restore
  • madisonfirst Jun 16, 2008
    i downlaoded some items today and after that i tried to shut it of then it make a tilt and its still on tilt not responding
  • 275 Answers
Products Affected iPhone, iPod touch
Symptoms that may have occurred with an unsuccessful restore may include a frozen screen—either at the Apple logo or some other application—or the device may repeatedly reset.
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting USB cable. When you reconnect USB, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again. I have an iphone I - ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message: ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Because you must restore iPhone or iPod touch, iTunes will not recover data from the device, but if it was previously synced on the same computer and the same user account, it should restore a backup (if available). See document 305744, "Updating and Restoring iPhone Software."
If you are still unable to restore the iPhone using this method, check Apple support for further troubleshooting and/or service options.
Note: If you sync both an iPhone and an iPod touch to the same computer, make sure you select the correct backup to restore your settings from (don't select an iPhone backup if you have an iPod touch and don't select an iPod touch backup if you have an iPhone).
Posted on May 01, 2008
I locked myself out of my iphone, wrong passcode, cant get in :(
you need to restore the iphone as a new iphone...this does mean you will loose everything on the phone though.. so before you follow the steps below connect your phone to itunes on comp and transfer purchases from iphone to comp ( on windows select file on a mac also select file)
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 25, 2010 | Apple iPhone 3G
Just got phone downloaded itunes inserted sim card, but i tunes logo is all that is coming up on front of phone what more do i need to download ?? or what should i do to get phone up and running?? advise...
your phone has gone into recovery mode, you need to connect it up to your comp with itunes loaded up, make sure your itunes is the most recent update.
itunes will then appear with a message saying that it has detected an iphone in recovery mode and that you need to restore so carry on with the restoration of the phone.
below is a step by step on how to restore your phone but on the last steps you need to make sure you restore the iphone as a new iphone. Once you have gone through all that it will basically go through the setup of it and the activation of the phone, Hope this helps!
The sensors on the screen of i phone 3gs cant feel anything
check with apple to see if your still in your warrenty and they'll fix it for you for free..you could try restoring your iphone first but it may not work, ive left the steps below for you to try restoring it, hope this helps!
I Forgot My Iphine Personal Passwordd, How do I Unlock It?
We usually forgot iPhone encrypted backup password, I did for my iPhone 4. I used application "iPhone Backup Password Unlocker" via http://goo.gl/lNtZb It helped me recover forgotten backup password quickly with pro techinques!
Dec 24, 2010 | Apple iPhone 3G
Applications not running
I had the same problem. It will soon freeze when you restart it. You must try and backup all your things with Itunes and then try going to SETTINGS, GENERAL, RESET (on your Iphone) and restore all the default settings. If that does not work then you will have to restore your Iphone on Itunes. This often happens to my unlocked phone, especially when I try dial someone. It just closes the application.
hope this helps
Jun 23, 2009 | Apple iPhone 3G
Cant download apps application on phone
the iphone will sync your apps but you shoudn't need to restore it ever. unless you absolutely need to
if you are downloading apps from the itunes store, they will show in the upper most side menu on itunes.
plug your phone in and when it mounts, it comes to the summary, which shows the ipod picture.
in the upper part above the ipod picture you will see tabs, click on the apps tab and choose your settings. IE sync all apps etc.
Click apply and you iphone will sync your apps. it may take a few minutes because it backs up your phone also transferring the apps on the phone to your computer to sync.
May 01, 2009 | Apple iPhone 3G Black Smartphone
Ants Application
Go to ebay and buy the Unlock Software, search and you will find a lot offers for the software at ebay.
May 02, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
152 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
