Question about Canon PowerShot SD870 IS Digital Camera
Focusing Still Photos with SD870 IS
For taking still photos, the SD870 IS manual instructs that one should press the shutter button halfway to set the focus. When the shot is focused, the camera should beep twice & the indicator light flash green. When I press the shutter halfway, the camera beeps once, and the indicator light turns orange. Even after I have held the shutter in this position for as long as 20 seconds, the camera still has not beeped twice, and the light has not turned green. When the shutter is fully depressed, and the photo has been taken, the indicator flashes green, as it should. My pictures don't appear to be in focus, so I assume that I'm doing something wrong. Thank you for any assistance you can give me.
  • ssweeton May 01, 2008
    Thank you for solving my problem. I apologize for bothering you with something I should have been able to figure out for myself. ssweeton
  • 2,039 Answers
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
Posted on May 01, 2008
Why are my photos blurry
I would think that you are not focusing your camera before fully depressing the shutter button Start by depressing your shutter button very lightly until you see the outline of a small square in the middle of the view finder . At that point you are in focus . Now fully depress the shutter button and take your picture . You must do this prior to taking each photo . Remember to just depress the shutter button about half way to focus your picture image , before pressing it fully . I hope this is of some help to you.
Apr 06, 2017 | Cameras
My Fujifilm Finepix XP21 takes pictures but always blurry and not focusing? Any body
Have you tried focusing before you take a photo? To do this, press down the shutter button on your camera but don't push it far enough to take a photo. This enables the camera to focus on what it's about to photograph before you press the shutter button again and take the photo.
Nov 25, 2014 | FujiFilm FinePix XP21
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
Auto focus problem
Well, if all the software is ok, maybe the button is damaged and not able to give the two modes any more. If the camera has done it´s fair share of pictures, maybe it needs some repairs... since you´re the first that I personaly have heard is in this situation.
Mechanical things get broken more easily than we want, I guess. I´d recommend a repair shop for your camera and let us know how you ended up, please.
Oct 12, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Auto focus problem
If you set the camera on "manual", it assumes you focused manually and allows you to press the shutter without having to stop half-way. Check your settings.
Oct 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Screen and photos turn dark when zoom is used
Take a look at the manual - sounds like you have accidentally changed the white balance setting - you will want to set it back.
Aug 07, 2009 | Canon PowerShot SD870 IS Digital Camera
Digital camera only takes blurry pictures
there are two thing that make this problem: 1. if your photos has shadow so you must decrease the shutter time or increase the ISO to solve the problem. 2. but if your photos are out of focus make sure that you select the suitable f.Stop and when you want to take photo first press shutter button halfway to make the camera focus and then check the focus point on display. if it's ok, press shutter fully and if it's not good try again. I hope this helps...
Oct 31, 2008 | Cameras
Fuji FinePix F40fd aoto focus
Camera fault sounds like make sure the A/F sensor window is not obscured Fuji Tech Support will know more.
Jul 12, 2007 | Fuji FinePix F40fd Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
