Question about T-Mobile Wing™ Smartphone
T-Mobile Wing no sound........
I have no sound coming out from my phone , it doesn't ring and i can't hear music but when i plug in the headset, i can hear sounds, ,like music and ringtone..... i did hard reset but still the same.... i really hope you can give me some advices because the T-mobile customer service place is asking me to pay $150 just for a replacement... WHAT A RIp off......Thanx!
  • 1 more comment
  • Anonymous May 02, 2008
    same problem here with the sound going out.. I'm on my THIRD t-mobile wing because the speaker on the previous two just stopped working. Phone would'nt ring or make any sort of sound..There should have been a recall on these things a while back.. Thank God for insurance and equipment replacement programs...
  • trey_nba Mar 05, 2009
    no sound
  • Anonymous Mar 28, 2009
    no fuckin sound for my t-mobile wing
Don't know if you've tried this yet, but adjust the volume slider on the left side of the phone. A screen will appear. One is for the phone volume and one is for the system volume..Sometimes one can be muted by accident. Also check your system settings under sound..Next, open Windows Media Player and make sure the volume is up. If that doesn't work I don't know what to tell you..I've had this phone for a while and that is one problem I have never seen.
Posted on May 02, 2008
Bh-503 audio cutting while listing music on my mobile
  • well i had an experience the same as you before, i think it's defend to your headset if your using a bluetooth headset or a cabled headset because if your using bluetooth headset and you're walking while listening you will hear the music cutting
Jan 24, 2013 | Nokia BH-503 Bluetooth Headset
Hi, one of our Call Center workers cannot hear the ringing phone when she has the headset onWhat's your problem?
The ring from the telephone is picked up by the internal microphone on the HL10 Handset Lifter, typically for most phones, the lifter sits directly over the speaker grill on the telephone where the sound comes out. For telephones that curve out on the left side and don't have a straight edge, there is an accessory called a "Ring Detector" which is used. Here's a link:
HL10 Nortel Adapter Kit - 46780-01
If the internal mic on the lifter has gone out, you can plug the ring detector into the handset lifter and just stick the ring detector over the speaker grill to pick up the ring. Plugging this into the lifter will bypass the internal mic, this accessory would have come with your HL10 lifter. You can also check the ring volume on the telephone, and you can also try adjusting the ring tone on the phone (sometimes it will pick up one ring tone better than another). Here is a link below if you need to order a new ring detector:
HL10 Nortel Adapter Kit 63014-01
Good luck from Headsets Direct!
Oct 27, 2011 | Plantronics PL-CS55 Wireless Headset
Can not hear the beep notification when a call comes in. Have moved the mic earpice up for more volumne, Any other solutions?
The lifer is what notifies your headset that it has an incoming call. Try turning the ringer volume up on your phone first and see if that solves the problem. If that does not help, it could be that the sensor on the lifter is going out. The lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help in picking up the sound of the phone's ring tones. If that doesn't help, you might consider replacing the lifter.
Mar 04, 2011 | Plantronics CS70 Wireless Headset
No speaker no sound on my treo
I had to have my Treo swapped once already because of a problem with the headset jack. The same problem is happening now - the phone always thinks the headset is plugged in (even when it isn't). That results in phone ringing (unless on virbate / silent mode) but no audio through the speaker in the back, and no speakphone icon appearing.
Given the symptoms you describe I would go to your service provider and (hopefully) get support under warranty - very likely hardware related.
Aug 10, 2008 | Palm Treo 650 Handheld
Palm treo
THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
Jul 29, 2008 | Palm Treo 680 Smartphone
No ring sound and music
at first you go the setting s in your mobile in there go for phone setting in that it given the default setting select it after one min you swicth off your mobile and swicth on the mobile you got the ring tone in your mobile
May 30, 2008 | Nokia 6111 Cellular Phone
T Mobile Wing bluetooth and music help please
Hi fazioli73,
With Bluetooth enabled cell phones, if it has a music player, the only device the music player will recognize to output audio is a set of Bluetooth Headphones, not a Bluetooth Headset.
Once you have the Bluetooth Headphones, set them into pairing mode. Then go into your Bluetooth options in your phone, and go into add/search for device. Once your phone recognizes your Bluetooth headphones, and you have it set as your main Bluetooth device, your music player should play through the headphones at that point.
Sincerely,
Gina, Communities Connection Manager
Creating meaningful communication in a virtual world
Mar 31, 2008 | T-Mobile Wing™ Smartphone
T-Mobile wing problems
When I went to my local T-mobile dealer about the sudden absence of any sound from my Wing, he suggested I take the battery out, then put it back in. It worked.
Since then I have discovered that sometimes this fix works (why?) and sometimes it doesn't.
Not happy at all here, to have spent so much on the phone and then find out that when I answer a phone call, I've no idea whether I'm going to be able to hear anything or not, and I may or may not be able to "fix" it.
If anyone has more insight on this, I'd sure like to hear it.
Dec 20, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
398 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
